v4.5.1.7 - stable
v4.5.1.7 - stable
Version 4.5.1.7 is out
What's New?
  • Time-Stretching To...added to Playlist
  • Transtion Ends at Out Option added
  • Apply to All when editing multiple tracks in TAG Editor
  • The internal WebBrowser is now based on Chromium (Edge)
  • RemoteVoiceTracking should now resolve EmbeddedContainer durations (as available)
  • ACM format support for ICEcast added
  • Media Library Server processing optimized
  • TrackInsertTransitions now end at CueOut instead of Next
  • Sweeper DragDrop optimized
  • HookQueue bug-fix to preserve EntryType
  • TAG data now also removes basic TAGs correctly
  • New UI- and Audio-Lib version
  • Various optimizations and smaller bug-fixes
  • stable
If you are already on Windows 11, you don't have to do anything, as Edge (Chromium) is already be installed on your machine by the OS.
The same is true, if you are on Windows 10 and have applied some of the recent Win10 updates.
Else, if you are still on Windows 8 or 7, you might need to install Chromium support manually from here:
https://go.microsoft.com/fwlink/p/?LinkId=2124703
