Proppfrexx dont Start after import some vst
RadioMusicHouse
Post by RadioMusicHouse »
Today i started again to work with Proppfrexx and i found some interesting vst wich one make the sound better ..... just import that and let them play and after a song the programm shut down and no error seen ..... i start it again and it came till the show " ready" and after it shut down suddenly ..... Please is there a chance to get a clean start with it? :?: :?: :?:
Re: Proppfrexx dont Start after import some vst
Sounds like the VST2 is buggy.
To remove it from any config, you might need to remove it from the file called "Default.mixer" in the ProppFrexx AppDataUser folder - you might need to remove the file entirely.
(%appdata%\radio42\ProppFrexx ONAIR\4.0)
