microphone monitor
fjb59
microphone monitor
Post by fjb59 »
is there a way in the software to temporary monitor the mic input both prefade and postfade?
Thank you
Re: microphone monitor
To you want to listen to the mic? If yes, you can use the SND2 function. But there is no difference between pre- or postfade, as the fader of the input channel controls the recording volume. Ie. if you lower the fader the recording is silence.
If ypu want to implement a kind of clean-feed, you can route the input to an output ‚sub-bus‘ channel and use this one.
fjb59
Post by fjb59 »
radio42 wrote: 24 Oct 2024 22:27 To you want to listen to the mic? If yes, you can use the SND2 function. But there is no difference between pre- or postfade, as the fader of the input channel controls the recording volume. Ie. if you lower the fader the recording is silence.
Thank you.
