Microphone on air but not in ears
This forum is unmoderated!
claudius06
Post by claudius06 »
Is it possible to configure the studio's microphone input so that it is not sent to the PFL, allowing me to monitor all inputs except the microphone, to avoid hearing myself with the delay caused by latency?
Thank you,
Claude.
Re: Microphone on air but not in ears
Sure, you can route the input to any output or even to no output channel at all.
If you need making of clean feed, you can even rout it to a new output channel, which is not used for anything else then sometimes SNDing it to the PFL.
The delay/latency might come from not using a low latency ASIO device/mode.
claudius06
Okay, I understand. Thanks again for your advice.
