Titel update Overlay Editor
Bob Van Dongen
Post by Bob Van Dongen »
Best,
I have the next challenge. If I load an Overlay with, for example, a news message, everything plays properly, but the title is not written properly. In the settings I choose Use Overlay Description under Title Update, but it does not do this, it keeps to the overlay name and what I choose in the adjacent column, for example (Weather). Can you tell me what I am doing wrong? Kind regards, Bob van Dongen
Re: Titel update Overlay Editor
I have just tested it here and it works as expected.
a) Have you provided a description?
b) are you using mutipe overlays (maybe they are combined, in such case only the first overlays defines the settings)
Maybe you can post a screenshot of your Overlay Scheduler and our Overlay Editor settings...
Bob Van Dongen
Thank you for your quick response, I have attached two images if all goes well. Hopefully you see something here that is not correct, if you need more information, please let me know
Overlay
Overlay
Overlay Editor
Overlay Editor
I have done the same. What version do you have? And how are you testing things.
Eg. enable the status bar of the Network Monitor window. In that status bar you will see what is being send to the streaming servers.
In my tests the overlay (once it started to play; scheduler was running) updated the song title of the streaming servers with the overlay description.
Bob Van Dongen
I am using version 4.4.2.0
It is a web link that I load via the script library editor.
Players A and B then write the title via EXEC_WRITE_FILE when that deck plays. That is why I would like to have something other than the link written down
Bob Van Dongen
Can you send me an image where I can find what you indicate?
Bob Van Dongen
Below I will place two images, one of Proppfrexx player and one of the text as it becomes visible to our listeners. I would like the blue circle not to be there because of cleanliness.
Have a nice day and thank you very much again for your response
Zichtbaar banner tekst.JPG (9.1 KiB) Viewed 9948 times
First also make sure you do not exclude streams from your title updates:
In the Network Monitor Window (where you define your streaming servers) make a right click and make sure the item 'StatusBar Visible' is checked.
Now you can see in the StatusBar the SongTitle Updates...:
As you can see, when the Overlay starts, the SongTitle is updated accordingly.
Here is the related Overlay:
Bob Van Dongen
Thanks for your response, I'll get to work on it
In that case (which is indeed a totally different case), you can define the name of the track title in the script-line when you define the container. I.e. here:
In addition you can also specify the script-line title entry, when clicking on the small 'T' icon on the mode column:
