Cartwall 1 doens’t start Auto play
This forum is unmoderated!
Noaber
Post by Noaber »
Hoi cartwall 2 does start de automatic Play after hè is Finich. How should i set that up??
Re: Cartwall 1 doens’t start Auto play
I am sorry, but I don’t understand your issue?
Can you explain in more detail what you mean!
What is finishing and what do you expect?
The cartwalls typically start manually.
If you want to play a jingle or station id automatically, you can schedule the cartwall in your script.
Noaber
Post by Noaber »
yes sorry for my english.i mean when the auto play is off and The player stops when I click on a jingle in the cartwall, the player then starts again and auto play is turned on again after the jingle has ended.
I am sorry, but this does NOT happen here!
And it is also NOT any default behavior of the cartwall.
Maybe you have assigned a control-command to the cartwall or the cart (track) - OR maybe you have set the 'StartAutoPlay' option with the track in the cartwall?
Else, this behavior seems impossible and I can not reproduce that here.
Please also specify, what exact ProppFrexx version you are using?
Noaber
Post by Noaber »
Can i send you a Movie of What i meen
You can send a movie of course, but that doesn’t answer my questions here…
Noaber
Post by Noaber »
The normal on air
a) I mean the version number of the software - it is displayed at startup and in the About Dialog, e.g. v4.4.2.0?
b) I mean my questions about the control-commands AND the track options and commands
Noaber
Post by Noaber »
The last up date b. I dont know. Where can i sent you the Movie
Noaber
Post by Noaber »
someone else installed propfrexx for me (bennie blom from team fm), I don't know if you know him.
