Proppfrexx hangs
This forum is unmoderated!
Bart ve
Proppfrexx hangs
Post by Bart ve »
Hi
I've two instances of proppfrexx running (on 2 computers: 1 laptop, 1 desktop). After the updtae (?) Proppfrexx on the laptop seems to "hang" after the start of a song or playlist. What can be the reason please?
TY.
Bart
Re: Proppfrexx hangs
Audio or Mixer settings, ie. check your IO Settings, Routing etc. probably the mixer is not playing to a device or the device used in the mixer channel is incorrect or not initialized.
Bart ve
Post by Bart ve »
I loaded a backup file; problem solved ! Thank you
