not start - hangs on the start window
Angold
Post by Angold »
I have a problem here with Proppfrex v4.4.0.4 Professional Edition.
The program does not start - hangs on the start window ....Please wait,
creating mixer.
I deleted the default.mixer file, on Bernd's advice. But the error mask appears and it starts all over again. Like a loop that I can't get out of ;(
Thanks for the help. Greetings, Andreas
Device name DESKTOP-8BEN7G9
Processor Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz 2.60 GHz
Installed RAM 32.0 GB (31.9 GB usable)
Device ID C69E4071-B007-492B-B04A-448779D4D749
Product ID 00330-50943-59354-AAOEM
System Type 64-bit operating system, x64 based processor
Windows 10
But it was already on this platform.
Thanks and greetings, Andreas
12.10.2023 22:50:25 [v4.4.0.3]:********** Error/Exception Information **********
Error Message: Access to the path 'C:\Users\golde\AppData\Roaming\radio42\ProppFrexx ONAIR\4.0\ProppFrexx ONAIR.userconfig' is denied.
Error Type: System.UnauthorizedAccessException
Error Source: mscorlib.Void WinIOError(Int32, System.String)
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at ProppFrexx.ProfileConfig.SetValue(String pSection, String pEntry, Object pValue)
at ProppFrexx.PFUserConfig.set_SkinName(String value)
at ProppFrexx.FirstTimeSetupWizard.SmC(Object , CancelEventArgs )
at DevExpress.XtraWizard.WizardControl.RaiseFinishClick()
at DevExpress.XtraWizard.WizardControl.OnFinishButtonClick(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevExpress.XtraEditors.BaseButton.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraEditors.XtraControl.WndProc(Message& m)
at DevExpress.Utils.Controls.ControlBase.BaseWndProc(Message& m)
at DevExpress.XtraEditors.BaseControl.WndProc(Message& msg)
at ProppFrexx.ProppFrexx_ONAIR.VA5A(Exception )
at ProppFrexx.ProppFrexx_ONAIR.PA5T(Exception )
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at ProppFrexx.ProppFrexx_ONAIR.rAAI()
at ProppFrexx.ProppFrexx_ONAIR.EAda()
at DevExpress.XtraEditors.DForm.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
at DevExpress.Utils.Taskbar.Core.FilterWindow.WndProc(Message& m)
at u1.e2.Main(String[] args)
********** End **********
12.10.2023 22:53:23 [v4.4.0.3]:********** Error/Exception Information **********
Re: not start - hangs on the start window
The given error message almost explains it all.
You don’t have user permission to access the given path:
Ie. you must grant the user to access that path.
Unfortunately I can not tell you from here, why this is the case. But your system administrator might tell you.
Eg. you have changed the user, it’s user rights etc.
Angold
Post by Angold »
Thanks for the tip, I'll take care of the rights. Many thanks, Andreas.
