Metadata from Overlay
mojeradio_uk
Post by mojeradio_uk »
I am a new user of the program and I cannot find the appropriate settings. Namely, I have newscasts 4 times in an hour. If they are played as an overlay to regular music files, everything is ok. Unfortunately, when played as an overlay to MODstream, the metadata is not displayed, metadata from MODstream is visible. Is there any way to do that?
Re: Metadata from Overlay
I can not really follow your settings.
By default, when an Overlay starts playing (and the MODStream is playing too at this time), the volume of the MODStream is muted and the Overlay is playing and the Overlay metadata is updated according to the Overlay settings.
Just tested it here.
So maybe your Overlay settings are different? Can you post them here, esp. a screenshot of the Overlay and all Options set.
