How to assign Track-Insert transition through command?
end0re
Post by end0re »
Hello, I looked through all the commands in the pdf and tried to find a command that allows me to assign Track-Insert transition to specific track, but I'm probably blind because I didn't find one :(
e.g. Through UI I can right click on a track -> Track Settings -> Special Element -> Insert Transition and set the Track-Insert transition and attenuation for that specific track, but how to do this through TCP command?
Thank you
Re: How to assign Track-Insert transition through command?
You are not bling (luckily).
Track-Insert-Transitions can not be assigned programmatically via control-commands dynamically at run-time in real-time.
What is your use case? Ie. I don’t see any need for providing such a control-command. Maybe there are other ways to achieve what you try to do…
end0re
Post by end0re »
I'm playing around right now, but basically the idea is to generate an audio file using TTS that says the current time and local weather and then I add it to playlist through TCP
Of course the current time might be a little off, but if I time it right then should be pretty accurate
Haha, that's good to know :D
I found an alternative way - if I create a new .pfp and then load track(s) from that playlist using PLS_CURRENT_APPEND_PLAYLIST then a whole new world of possibilities opens up (yay)
Thank you
end0re
Post by end0re »
Are there more ways to do this? I guess I should improve the timing of what time the TTS says with the exact track after which the TTS file will be played (is there a command to get the end time of specific track? Then I can use that track end time as the "current time" that the TTS says)
EDIT: I see there is PLS_CURRENT_GET_ENTRY so it means I can calculate track end time by doing (schedule + playtime) right?
Yes, that might exactly be the way. PLS_CURRENT_GET_ENTRY actually returns most information about the referenced track.
(player|#|filename|trackname|duration|playtime|schedule|status|elapsedtime|remaintime|album|year|genre|ramp|outro)
You need to parse and extract the info though, which you need...i.e. coding is required on your side.
But I guess you need to do this anyhow for your TTS ;-)
