vst 3 support
fjb59
vst 3 support
Post by fjb59 »
hello. i have some vst vocal plugins i'd like to use with proppfrexx. Sadly it doesn't yet support vst 3. would you add this facility in a near release? Thank you.
Re: vst 3 support
I am not sure I can, as there is currently not support for VST v3 within the BASS audio system (which I am using). As such, as long as there is no support, I cannot offer this.
GuntherM
Re: vst 3 support
Post by GuntherM »
Hi guys, I thought, you can use the native DLL files from the plugins, correct me if I'm wrong?
SevenSenses
Re: vst 3 support
Post by SevenSenses »
Yes that would be a great idea.
I've wanted to pick up on this one too.
Too bad it's not that easy to implement.
Since all VSTs will change to v3 really soon, which I've noticed (I-zotope ect...).
Maybe one day there will be a further development of the library you are using. Let's just keep our eyes open :-)
Gettings Tom from Vienna.
GuntherM
Re: vst 3 support
Post by GuntherM »
I have a playlist rider, a AGC on steroids, which I like to use on every channel, so if Propp accept the DLL plugin, We don't have to use an outboard AGC anymore, and fully digital.
SevenSenses
Re: vst 3 support
Sounds interesting, :)
I don't really care if PF can do VST 3. (a nice to have).
But it would be worth keeping your eyes open here in any case if it were really possible.
Every now and then I use I-Zotope 64bit VST2 and it works perfectly.
Otherwise the whole thing will run out of an Optimod.
Re: vst 3 support
If you you are mainly looking for a very good AGC, I’d recommend looking to the following:
- StereoTool
- ToneBoosters
Both are available as excellent VST2 plug-ins.
fjb59
Re: vst 3 support
Post by fjb59 »
i went on the bass support forum and it looks like they are migrating to vst 3
Re: vst 3 support
I saw the post, but the discussion is going on since May this year but so far with no progress… but I am watching it!
fjb59
Re: vst 3 support
Post by fjb59 »
radio42 wrote: 11 Aug 2022 16:07 I saw the post, but the discussion is going on since May this year but so far with no progress… but I am watching it!
they were after a programmer, although i'm familier with the c familiy of languages, i haven't written a dll since the nineties.
