Copy Shows within Scheduler and Overlay Scheduler
TomNick
Post by TomNick »
Hi everybody,
I am wondering if there is any way to copy a specific show to another date in the scheduler. E.g. 20.00 to 0.00 on Saturday needs to be played on Wednesday from 13.00 to 19.00 as well. Could not figure out how to do that. Thanks for some help.
Re: Copy Shows within Scheduler and Overlay Scheduler
The depends of what type of show you would like to 'rebroadcast'?!
If it was maybe a Live Show, you first need to record that show, which can then be replayed at a later date.
E.g. you might start and stop recording a certain mixer channel using the 'On Program Started/Stopped' events of the related program scheduler entries (click on the 'Control Commands...' button in the Program Editor dialog).
Use e.g. the 'MIXER_OUTPUT_REC_ON/OFF <mixerchannelname>' control-commands to do so. This will record a mixer output channel when the program is started/stopped.
You then can reboradcast this recorded file - this is all explained here:
https://www.proppfrexx.radio42.com/foru ... hp?p=13463
and here:
https://www.proppfrexx.radio42.com/foru ... hp?p=11968
