History
djbony
History
Post by djbony »
could history be made as in the picture? When you click on a track in the playlist or in the search engine, it will be displayed when it was played or will be. You can filter by artist or title. This allows you to control the rotation when adding songs manually.
Re: History
ProppFrexx doesn’t store this information. Only the last played date and the total number (count) of play outs are stored per track. This can be viewed via ALT+2 for example.
But, there is actually a separate Statistic app (freely available in the install folder). In this app you can search for tracks when exactly they have been played in the past.
A look into the future is not possible with ProppFrexx - even when you pre-create playlists, as this info is not stored in any database or alike.
djbony
Re: History
Post by djbony »
Looking to the future would not matter at all :) But if a playlist were generated in advance, the data would be available. And it was the implementation of the Statistic application in PFOA that I had in mind. But shown by a dot in the hour and date the track or artist played in the past. Just such an idea for improvement in the future ...
Re: History
The data is not there in the statistics app for the future. That’s what I tried to explain. As only the pre-generated playlist exists nothing more.
The history played data is as said available in the Statistics app.
