Repating Show
TomNick
Repating Show
Post by TomNick »
Hi again,
A show runs scheduled from 20.00 to 22.00 including voicetracks. Same show shall repeat next morning from 02.00 to 04.00. Any configuration idea is appreciated. Thank you
Re: Repating Show
I assume, that there are no 'live' elements etc. in it...
As such, just create a 2nd program scheduler entry to simply re-schedule the same show/files/script also at the next morning time.
If the script or program is dynamically created and contains time macros, you might want to use the *[DATE:... macro, e.g. to transform the original date and e.g. subtract 6 hours to go back to the original date; e.g. *[DATE:{${start}}:{hours}:{-6}:{yyyyMMdd_HHmm}]
That will e.g. return "20210610_2000", if the 2nd program entry starts at "2021-06-11 02:00:00".
