problem after latest update
Michel67
Post by Michel67 »
8-11-2020 20:37:49 [v4.2.1.1]:********** Error/Exception Information **********
Error Message: Could not load file or assembly 'DevExpress.XtraScheduler.v20.2.Core.Desktop, Version=20.2.3.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Error Type: System.IO.FileLoadException
Error Source: ProppFrexx ONAIR.Void PbOR()
at ProppFrexx.ProppFrexx_ONAIR.PbOR()
at ProppFrexx.ProppFrexx_ONAIR..ctor(Arguments CommandLine)
********** End **********
PF wont start
Re: problem after latest update
Please reinstall using this link below and unzip this to your target installation folder (while ProppFrexx and all reated apps are closed).
The current update is already fixed (here was only an incorrect file for the first 15 minutes - seems you just got exactly that ;)
Michel67
Post by Michel67 »
solved! Thanks
Berthold
Post by Berthold »
after the last update v4.2.1.1, if I want to move a song to position 1 or 2 in the playlist, ProppFrexx crashes (players are activated), or does the problem only occur with me? Screen freezes. Thanks !
No, that is a confirmed bug. I'll provide an update asap!
