Moving library location
Thijmen
Post by Thijmen »
I was wondering what would be the best way to move a library location?
E.g. media library X has path XX.
I want to move the path to YY.
However, media libary X is also being used in scripts. I preferably do not want to change scripts.
Is there any easy way to do this? Thanks!
Re: Moving library location
The scripts just refer to the lib name.
So as long as the lib name stays the same, there is no problem!
Sounds like you are using a Folder based lib?
If yes, make sure, the new lib has the exact same name as the old one.
Thijmen
Post by Thijmen »
Alright, thank you Bernd!
