TITLE UPDATE ERROR
Thijmen
TITLE UPDATE ERROR
Post by Thijmen »
Sometimes I see that the stream title is not being updated on track change... the streamer says: TITLE UPDATE ERROR.
Is there any way to debug this?
Re: TITLE UPDATE ERROR
Does it always show it or only sometimes.
If it is only sometimes, it is typically an issue on the server side, eg. a network issue, which needs to be debugged on the server side.
A detailed client error message can be retrieved by clicking on the icon at the left of the entry row showing the error.
If it is a constant error, it is probably an issue with the streaming settings, eg. the credentials.
However this is in any case not a bug!
Thijmen
Post by Thijmen »
@radio42,
Is there any way to get more verbose logging? TITLE UPDATE ERROR is pretty.... generic.
Thijmen
Post by Thijmen »
By the way, I cannot click any icon...
There are two icons shown click on the 2nd one.
The one with the warning sign in it.
Thijmen
Post by Thijmen »
I see, I tried both single and double clicking the warning icon, nothing pops up.
Try a right-click
Thijmen
Post by Thijmen »
Right click also did not work... I replaced the streaming server with another one, seems to work. Might be my server.
Another question: I notice that Proppfrexx not directly updates the song on track change - is there any way to achieve that?
Here it does!
What is happening on your side? And when does it update on your side?
And how are you testing it? On the server side or on a listener side?
If it is on the client listener side, this a buffer issue and might again be due to a configuration on the server side!
Thijmen
Post by Thijmen »
I am using Icecast and the stream update is really delayed.. Just using plain Icecast, no other config used. Any way to debug this?
Can I log the calls for updating the stream title?
