overlays embeded issue in the last 2 betas
moogwill
Post by moogwill »
something goes wrong in the last 2 betas, seems embeded overlays are not saved in the RVT sessions..
easy to reproduce, they are in the playlist when generated, but they arent after you re open the playlist.
Re: overlays embeded issue in the last 2 betas
I am trying to investigate, but as this is a Beta-Version you are using, you might roll back to the last stable version!
moogwill
Post by moogwill »
maybe a stupid question: how to roll back?
Download and Install that latest official.
Normally, there is also a 'Previous Verison' folder underneath the installation folder, which contains the backup of the last update/version, which can be used to roll-back.
But as you already 2 betas, this is not possible anymore.
moogwill
Post by moogwill »
is there a direct link or do i have to re enter my email adress?
Just use the default download form by providing the address.
Just found the bug, which indeed was added to a recent beta-version. It will be fixed soon in another beta first.
Fixed in the latest v4.0.5.17 update.
