Script line skipped without clear reason
mdegroot
Post by mdegroot »
I'm having a problem and I can't find a solution.
I will try to explain the problem.
I have a script running. In the script, I have a container loading another script called "uittip". It's a small item, playing every hour.
In that "uittip" script, I only have 3 script lines. A jingle to start, the item itself, and a jingle to stop. The 2 jingles are fixed. The item is a media library containing 6 or 7 files, randomly chozen.
This is working well for a couple of months now, but since last week only the start and end jingle are playing. The item isn't.
The media library with the item is still containing 7 files, no dead entry's. File path's aren't changed.
When I test the "uittip" script, it's nicely showing 3 files (start, item, stop) without any errors.
When i open a "new playlist from script template" and i choose the "uittip" script, I have 3 items (start, item, stop).
Only when the "uittip" script in loaded into the daily playing script in a container, or when I add the "uittip" script in a container to an existing playlist , I'm only getting 2 items (start and stop jingle). the item itself doesn't play.
Screenshots below.
Any idea what's going wrong?
Grts,
Re: Script line skipped without clear reason
Have you tested you main script? (As in the above screenshot I can only see the test of the uittip script alone). Can you then send me that log output?
The only change made in the last version was a correction with the RuleSet evaluations. Are you maybe using any on that random tracks?
mdegroot
Post by mdegroot »
We had this problem already before the latest updates but I didn't had the time to check this out yet.
Every week I change the item files and then it seems that the "uittip"script is working again.
I putted the new files into the directory a couple of minutes ago and did a new test by adding the "uittip" script in a container into the loaded playlist and the 3 files were now correctly picked. Without changing any setting. Looks like a history thing, but "suppres history check" and "suppres add history" are set to this line. And for a few months we didn't have this issue.
When the fault occures, I can add a container with this script to any of our scripts or running playlists, the file isn't playing. Even when I load an empty playlist and I add a container with the script in it, the item file is skipped. Only when I start a new playlist from scripts template, the file is picked correctly. It's very strange.
2 months ago we had the same issue with the jingles. Mostly all of our jingles were suddenly skipped without any reason.
Only solution then was to make a new media library for the jingles with a new name, and then all jingles played again without problem.
For now it's working again, when the problem returns this week I let you know.
Grts,
Ok. I’ll also lakeside tests next week to see, if I can somehow reproduce it.
However, if you face this again, pls test your main script and send me the full log.
mdegroot
Post by mdegroot »
Everything worked well last week, this week, the "uittip" item played well on monday, thuesday, and wednesday. Thursday and friday, the item was skipped again. This is a screenshot of one of the main scripts and also the full test log of that script and the PLAY LOG of one of the hours yesterday were you can see it's only playing 2 script lines instead of 3 :
TEST LOG :
22/12/2018 15:50:57: Script Test started for : DAG NONSTOP
22/12/2018 15:50:57: Processing Script-Line 1 (Retries=240): 1 Container : OVERLAY:TOP OF THE HOUR|180|Embedded Container (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:57: GetNextTracks processed, 1 script result entries returned (File=OVERLAY:TOP OF THE HOUR).
22/12/2018 15:50:57: Processing Script returned: Embedded Container (File=OVERLAY:TOP OF THE HOUR).
22/12/2018 15:50:57: Processing Script-Line 2 (Retries=240): 1 Container : OVERLAY:POWER|120|Embedded Container (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:57: GetNextTracks processed, 1 script result entries returned (File=OVERLAY:POWER).
22/12/2018 15:50:57: Processing Script returned: Embedded Container (File=OVERLAY:POWER).
22/12/2018 15:50:57: Processing Script-Line 3 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: Global-History: entry 'Artist' is contained in history (Entry=U2 - I Still Haven't Found What I'm Looking For, Artist=U2, MaxHistory=60)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Midnight Oil - Beds Are Burning.mp3).
22/12/2018 15:50:58: Processing Script returned: Midnight Oil - Beds Are Burning (File=C:\Audio\RK AUDIO 2014\80\Midnight Oil - Beds Are Burning.mp3).
22/12/2018 15:50:58: Processing Script-Line 4 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Hall & Oates - Kiss On My List.mp3).
22/12/2018 15:50:58: Processing Script returned: Hall & Oates - Kiss On My List (File=C:\Audio\RK AUDIO 2014\80\Hall & Oates - Kiss On My List.mp3).
22/12/2018 15:50:58: Processing Script-Line 5 (Retries=240): 1 Random : Algemeen kompas (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas Xmas Liner - 100% Kerst ,Ho Ho Ho Festive Fun For Everyone! (With Male Voice), LastPlayed=22/12/2018 13:47:28, ScheduledAt=22/12/2018 16:03:51)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas Xmas Liner - 100% Kerst ,Ho Ho Ho Festive Fun For Everyone! (With Male Voice), At=22/12/2018 16:03:51)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas - Artist drops, Radio Kompas wenst je een gelukkig nieuwjaar en veel classics in 2019, LastPlayed=22/12/2018 14:42:09, ScheduledAt=22/12/2018 16:03:51)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Artist drops, Radio Kompas wenst je een gelukkig nieuwjaar en veel classics in 2019, At=22/12/2018 16:03:51)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is contained in history (Entry=Radio Kompas - Elke dag een reis, Kompas, de Classics, Artist=radio kompas, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Elke dag een reis, Kompas, de Classics, At=22/12/2018 16:03:51)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas - 2019 is het jaar van de classics, Radio Kompas Classics, LastPlayed=22/12/2018 15:44:21, ScheduledAt=22/12/2018 16:03:51)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - 2019 is het jaar van de classics, Radio Kompas Classics, At=22/12/2018 16:03:51)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\AUDIO 2019\Algemene jingles kompas\Radio Kompas ,Happy Christmas (Fast To Med).mp3).
22/12/2018 15:50:58: Processing Script returned: Radio Kompas Xmas Liner - Radio Kompas ,Happy Christmas (Fast To Med) (File=C:\AUDIO 2019\Algemene jingles kompas\Radio Kompas ,Happy Christmas (Fast To Med).mp3).
22/12/2018 15:50:58: Processing Script-Line 6 (Retries=240): 1 Random : 90 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\90\Eros Ramazzotti - Cose della vita (Can't Stop Thinking of You).mp3).
22/12/2018 15:50:58: Processing Script returned: Eros Ramazzotti & Tina Turner - Cose della vita (Can't Stop Thinking of You) (File=C:\Audio\RK AUDIO 2014\90\Eros Ramazzotti - Cose della vita (Can't Stop Thinking of You).mp3).
22/12/2018 15:50:58: Processing Script-Line 7 (Retries=240): 1 Container : OVERLAY:publislot1|60|Embedded Container (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=OVERLAY:publislot1).
22/12/2018 15:50:58: Processing Script returned: Embedded Container (File=OVERLAY:publislot1).
22/12/2018 15:50:58: Processing Script-Line 8 (Retries=240): 1 Random : 70 (Filter=, Options=None)
22/12/2018 15:50:58: MediaLibrary 70 CheckSongHistory: entry directly contained in media history (AC-DC - Highway To Hell)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\70\Ace - How Long.mp3).
22/12/2018 15:50:58: Processing Script returned: Ace - How Long (File=C:\Audio\RK AUDIO 2014\70\Ace - How Long.mp3).
22/12/2018 15:50:58: Processing Script-Line 9 (Retries=240): 1 Random : Algemeen kompas (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is contained in history (Entry=Radio Kompas - Dit is Radio Kompas, 2019 meer Classics, Artist=radio kompas, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Dit is Radio Kompas, 2019 meer Classics, At=22/12/2018 16:12:46)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is contained in history (Entry=Radio Kompas - Classics Mix 01, Artist=radio kompas, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Classics Mix 01, At=22/12/2018 16:12:46)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is contained in history (Entry=Radio Kompas - Een mooier eindejaar en een prachtig begin van 2019, wij zijn er klaar voor, Radio Kompas kiest voor Classics, Artist=radio kompas, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Een mooier eindejaar en een prachtig begin van 2019, wij zijn er klaar voor, Radio Kompas kiest voor Classics, At=22/12/2018 16:12:46)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is contained in history (Entry=Radio Kompas - Classics Mix 09, Artist=radio kompas, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Classics Mix 09, At=22/12/2018 16:12:46)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Elke dag een reis, Kompas, de Classics, At=22/12/2018 16:12:46)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is contained in history (Entry=Radio Kompas - Wij draaien ze echt allemaal, Radio Kompas Classics, Artist=radio kompas, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Wij draaien ze echt allemaal, Radio Kompas Classics, At=22/12/2018 16:12:46)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas Xmas Liner - 100% Kerst ,Ho Ho Ho Festive Fun For Everyone! (With Male Voice), LastPlayed=22/12/2018 13:47:28, ScheduledAt=22/12/2018 16:12:46)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas Xmas Liner - 100% Kerst ,Ho Ho Ho Festive Fun For Everyone! (With Male Voice), At=22/12/2018 16:12:46)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is contained in history (Entry=Radio Kompas - Classics, Bye Bye Hits (01), Artist=radio kompas, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Classics, Bye Bye Hits (01), At=22/12/2018 16:12:46)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is contained in history (Entry=Radio Kompas - Classics Mix 06, Artist=radio kompas, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Classics Mix 06, At=22/12/2018 16:12:46)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\AUDIO 2019\Algemene jingles kompas\Jingle Bells All The Way ,Een Fijne Kerst En Een Gelukkig Nieuwjaar ,Radio Kompas With Bells (Med To Fast).mp3).
22/12/2018 15:50:58: Processing Script returned: Radio Kompas Xmas Liner - Jingle Bells All The Way ,Een Fijne Kerst En Een Gelukkig Nieuwjaar ,Radio Kompas With Bells (Med To Fast) (File=C:\AUDIO 2019\Algemene jingles kompas\Jingle Bells All The Way ,Een Fijne Kerst En Een Gelukkig Nieuwjaar ,Radio Kompas With Bells (Med To Fast).mp3).
22/12/2018 15:50:58: Processing Script-Line 10 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\P. Lion - Happy Children.mp3).
22/12/2018 15:50:58: Processing Script returned: P. Lion - Happy Children (File=C:\Audio\RK AUDIO 2014\80\P. Lion - Happy Children.mp3).
22/12/2018 15:50:58: Processing Script-Line 11 (Retries=240): 1 Container : OVERLAY:OVL20|120|Reklameblok 1 (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=OVERLAY:OVL20).
22/12/2018 15:50:58: Processing Script returned: Reklameblok 1 (File=OVERLAY:OVL20).
22/12/2018 15:50:58: Processing Script-Line 12 (Retries=240): 1 Random : Algemeen kompas (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\AUDIO 2019\Algemene jingles kompas\Most Wonderfull Time ,Merry Xmas ,Radio Kompas.mp3).
22/12/2018 15:50:58: Processing Script returned: Radio Kompas Xmas Liner - Most Wonderfull Time ,Merry Xmas ,Radio Kompas (File=C:\AUDIO 2019\Algemene jingles kompas\Most Wonderfull Time ,Merry Xmas ,Radio Kompas.mp3).
22/12/2018 15:50:58: Processing Script-Line 13 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
22/12/2018 15:50:58: Global Scripting-Restriction: entry 'Artist' is relaxed contained in history (Entry=Huey Lewis - Heart and soul, Artist1=huey lewis, Artist2=huey lewis & the news, DontRepeatArtistCount=15)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Huey Lewis - Heart and soul, At=22/12/2018 16:18:07)
22/12/2018 15:50:58: MediaLibrary 80 (C:\) CheckSongHistory: entry directly contained in media history (Human League - Love Action (I Believe in Love))
22/12/2018 15:50:58: MediaLibrary 80 (C:\) CheckSongHistory: entry directly contained in media history (Human League - Mirror Man)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Human League - The Lebanon.mp3).
22/12/2018 15:50:58: Processing Script returned: Human League - The Lebanon (File=C:\Audio\RK AUDIO 2014\80\Human League - The Lebanon.mp3).
22/12/2018 15:50:58: Processing Script-Line 14 (Retries=240): 1 Container : OVERLAY:dubbelhit|240|Embedded Container (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=OVERLAY:dubbelhit).
22/12/2018 15:50:58: Processing Script returned: Embedded Container (File=OVERLAY:dubbelhit).
22/12/2018 15:50:58: Processing Script-Line 15 (Retries=240): 1 Random : ANYOF:70, 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: Script-History: entry 'Album' is contained in history (Entry=Lou Reed - Perfect Day, Album=Vol 3 - Hey Little Girl, MaxHistory=35)
22/12/2018 15:50:58: MediaLibrary 80 (C:\) CheckSongHistory: entry directly contained in media history (Eurythmics - Miracle Of Love)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Eurythmics - Right By Your Side.mp3).
22/12/2018 15:50:58: Processing Script returned: Eurythmics - Right By Your Side (File=C:\Audio\RK AUDIO 2014\80\Eurythmics - Right By Your Side.mp3).
22/12/2018 15:50:58: Processing Script-Line 16 (Retries=240): 1 Random : Algemeen kompas (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas - Classics Mix 11, LastPlayed=22/12/2018 14:49:25, ScheduledAt=22/12/2018 16:29:19)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Classics Mix 11, At=22/12/2018 16:29:19)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\AUDIO 2019\Algemene jingles kompas\Radio Kompas - Classics Mix 04.mp3).
22/12/2018 15:50:58: Processing Script returned: Radio Kompas - Classics Mix 04 (File=C:\AUDIO 2019\Algemene jingles kompas\Radio Kompas - Classics Mix 04.mp3).
22/12/2018 15:50:58: Processing Script-Line 17 (Retries=240): 1 Random : 70 (Filter=, Options=None)
22/12/2018 15:50:58: MediaLibrary 70 CheckSongHistory: entry directly contained in media history (Ace - How Long)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\70\Adrian Gurvitz - Classic.mp3).
22/12/2018 15:50:58: Processing Script returned: Adrian Gurvitz - Classic (File=C:\Audio\RK AUDIO 2014\70\Adrian Gurvitz - Classic.mp3).
22/12/2018 15:50:58: Processing Script-Line 18 (Retries=240): 1 Container : SCRIPT:ITEM uittip|60|UITTIP|0 (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=ITEM uittip).
22/12/2018 15:50:58: Processing Script returned: UITTIP (File=ITEM uittip).
22/12/2018 15:50:58: Processing Script-Line 19 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Kool & The Gang - Fresh.mp3).
22/12/2018 15:50:58: Processing Script returned: Kool & The Gang - Fresh (File=C:\Audio\RK AUDIO 2014\80\Kool & The Gang - Fresh.mp3).
22/12/2018 15:50:58: Processing Script-Line 20 (Retries=240): 1 Random : ANYOF:70, 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\70\Diana Ross - My Old Piano.mp3).
22/12/2018 15:50:58: Processing Script returned: Diana Ross - My Old Piano (File=C:\Audio\RK AUDIO 2014\70\Diana Ross - My Old Piano.mp3).
22/12/2018 15:50:58: Processing Script-Line 21 (Retries=240): 1 Container : OVERLAY:OVL40|120|Reklameblok 2 (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=OVERLAY:OVL40).
22/12/2018 15:50:58: Processing Script returned: Reklameblok 2 (File=OVERLAY:OVL40).
22/12/2018 15:50:58: Processing Script-Line 22 (Retries=240): 1 Random : Algemeen kompas (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas - Classics Mix 10, LastPlayed=22/12/2018 14:29:04, ScheduledAt=22/12/2018 16:43:10)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Classics Mix 10, At=22/12/2018 16:43:10)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\AUDIO 2019\Algemene jingles kompas\Klaar voor de classics op het einde van het jaar, 2019, Radio Kompas Classics.mp3).
22/12/2018 15:50:58: Processing Script returned: Radio Kompas - Klaar voor de classics op het einde van het jaar, 2019, Radio Kompas Classics (File=C:\AUDIO 2019\Algemene jingles kompas\Klaar voor de classics op het einde van het jaar, 2019, Radio Kompas Classics.mp3).
22/12/2018 15:50:58: Processing Script-Line 23 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: MediaLibrary 80 (C:\) CheckSongHistory: entry directly contained in media history (Chris Isaak - Wicked Game)
22/12/2018 15:50:58: MediaLibrary 80 (C:\) CheckSongHistory: entry directly contained in media history (Chris Rea - I Can Hear Your Heart Beat)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Christians - Ideal world.mp3).
22/12/2018 15:50:58: Processing Script returned: Christians - Ideal world (File=C:\Audio\RK AUDIO 2014\80\Christians - Ideal world.mp3).
22/12/2018 15:50:58: Processing Script-Line 24 (Retries=240): 1 Random : ANYOF:70, 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\70\The Boys Town Gang - Cant take my eyes of you.mp3).
22/12/2018 15:50:58: Processing Script returned: The Boys Town Gang - Cant take my eyes of you (File=C:\Audio\RK AUDIO 2014\70\The Boys Town Gang - Cant take my eyes of you.mp3).
22/12/2018 15:50:58: Processing Script-Line 25 (Retries=240): 1 Container : OVERLAY:publislot1|60|Embedded Container (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: Processing Script-Line 26 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Pet Shop Boys - It's A Sin.mp3).
22/12/2018 15:50:58: Processing Script returned: Pet Shop Boys - It's A Sin (File=C:\Audio\RK AUDIO 2014\80\Pet Shop Boys - It's A Sin.mp3).
22/12/2018 15:50:58: Processing Script-Line 27 (Retries=240): 1 Random : Algemeen kompas (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\AUDIO 2019\Algemene jingles kompas\Merry Christmas And Happy Holidays ,Radio Kompas (Fast).mp3).
22/12/2018 15:50:58: Processing Script returned: Radio Kompas Xmas Liner - Merry Christmas And Happy Holidays ,Radio Kompas (Fast) (File=C:\AUDIO 2019\Algemene jingles kompas\Merry Christmas And Happy Holidays ,Radio Kompas (Fast).mp3).
22/12/2018 15:50:58: Processing Script-Line 28 (Retries=240): 1 LeastRecentlyPlayed : 70 (Filter=, Options=None)
22/12/2018 15:50:58: Get Random Track 70: TrackPointer=0, TrackCount=421, Filter=LeastRecentlyPlayed, TargetDuration=
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\70\The Bellamy Brothers - Let Your Love Flow.mp3).
22/12/2018 15:50:58: Processing Script returned: The Bellamy Brothers - Let Your Love Flow (File=C:\Audio\RK AUDIO 2014\70\The Bellamy Brothers - Let Your Love Flow.mp3).
22/12/2018 15:50:58: Processing Script-Line 29 (Retries=240): 1 Random : Algemeen kompas (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas - 2019 is het jaar van de classics, Radio Kompas Classics, LastPlayed=22/12/2018 15:44:21, ScheduledAt=22/12/2018 17:00:54)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - 2019 is het jaar van de classics, Radio Kompas Classics, At=22/12/2018 17:00:54)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas - Radio Kompas - Classics (Christmas Whoosh), LastPlayed=22/12/2018 14:10:03, ScheduledAt=22/12/2018 17:00:54)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Radio Kompas - Classics (Christmas Whoosh), At=22/12/2018 17:00:54)
22/12/2018 15:50:58: GlobalScriptRule-Restriction: track played in same hour (Track=Radio Kompas - Classics Mix 10, LastPlayed=22/12/2018 14:29:04, ScheduledAt=22/12/2018 17:00:54)
22/12/2018 15:50:58: Scripting-GlobalScriptRule: track matches rule and was suppressed (Track=Radio Kompas - Classics Mix 10, At=22/12/2018 17:00:54)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\AUDIO 2019\Algemene jingles kompas\Radio Kompas - Classics Mix 01.mp3).
22/12/2018 15:50:58: Processing Script returned: Radio Kompas - Classics Mix 01 (File=C:\AUDIO 2019\Algemene jingles kompas\Radio Kompas - Classics Mix 01.mp3).
22/12/2018 15:50:58: Processing Script-Line 30 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Michael Jackson - Wanna Be Startin' Somethin'.mp3).
22/12/2018 15:50:58: Processing Script returned: Michael Jackson - Wanna Be Startin' Somethin' (File=C:\Audio\RK AUDIO 2014\80\Michael Jackson - Wanna Be Startin' Somethin'.mp3).
22/12/2018 15:50:58: Processing Script-Line 31 (Retries=240): 1 Random : 80 B (Filter=, Options=None)
22/12/2018 15:50:58: MediaLibrary 80 B CheckGlobalHistory: entry directly contained in global history (Alicia Bridges - I Love The Nightlife)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80 B\Alison Moyet - All Cried Out.mp3).
22/12/2018 15:50:58: Processing Script returned: Alison Moyet - All Cried Out (File=C:\Audio\RK AUDIO 2014\80 B\Alison Moyet - All Cried Out.mp3).
22/12/2018 15:50:58: Processing Script-Line 32 (Retries=240): 1 Random : 70 (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\70\Creedence Clearwater Revival - Have You Ever Seen The Rain.mp3).
22/12/2018 15:50:58: Processing Script returned: Creedence Clearwater Revival - Have You Ever Seen The Rain (File=C:\Audio\RK AUDIO 2014\70\Creedence Clearwater Revival - Have You Ever Seen The Rain.mp3).
22/12/2018 15:50:58: Processing Script-Line 33 (Retries=240): 1 Random : Algemeen kompas (Filter=, Options=SuppressHistoryCheck, SuppressAddHistory)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\AUDIO 2019\Algemene jingles kompas\Prettige Feestdagen Radio Kompas, nog meer classics in 2019.mp3).
22/12/2018 15:50:58: Processing Script returned: Radio Kompas - Prettige Feestdagen Radio Kompas, nog meer classics in 2019 (File=C:\AUDIO 2019\Algemene jingles kompas\Prettige Feestdagen Radio Kompas, nog meer classics in 2019.mp3).
22/12/2018 15:50:58: Processing Script-Line 34 (Retries=240): 1 Random : 80 (C:\) (Filter=, Options=None)
22/12/2018 15:50:58: GetNextTracks processed, 1 script result entries returned (File=C:\Audio\RK AUDIO 2014\80\Fine Young Cannibals - Good Thing.mp3).
22/12/2018 15:50:58: Processing Script returned: Fine Young Cannibals - Good Thing (File=C:\Audio\RK AUDIO 2014\80\Fine Young Cannibals - Good Thing.mp3).
PLAY LOG :
2018-12-21 14:00:00, "DAG NONSTOP @ 21/12/2018 14:00:00", "Dag (Regular Show)", "DAG NONSTOP [DAG NONSTOP.pfs]"
2018-12-21 14:00:00, "TrackPlay", "EmbeddedContainer", "OVERLAY:TOP OF THE HOUR", " [7 Entries]", "Embedded Container", "Embedded Container", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "-1.000", "2018-12-21 14:00:00", 252.785, 252
2018-12-21 14:04:12, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\The Cure - Just Like Heaven.mp3", "The Cure", "Just Like Heaven", "", "", "1987", "", "", "", "100", "", "", "", "", "", "", "", "", "153.116", "2018-12-21 14:04:12", 205.788, 204
2018-12-21 14:07:36, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\Flash & The Pan - Midnight Man.mp3", "Flash & The Pan", "Midnight Man", "", "", "", "Pop", "80s", "", "100", "", "", "", "", "", "", "", "", "119.797", "2018-12-21 14:07:36", 281.645, 281
2018-12-21 14:12:16, "TrackPlay", "Jingle", "C:\AUDIO 2019\Algemene jingles kompas\Dit is Radio Kompas, 2019 meer Classics.mp3", "Radio Kompas", "Dit is Radio Kompas, 2019 meer Classics", "", "", "2018", "Blues", "", "", "0", "", "", "", "", "", "", "", "", "160.504", "2018-12-21 14:12:16", 6.414, 6
2018-12-21 14:12:22, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\90\Phil Collins - Something Happened On The Way To Heaven.mp3", "Phil Collins", "Something Happened On The Way To Heaven", "", "Phil Collins", "1990", "Eurodance", "90s", "", "100", "", "", "", "", "", "", "", "", "76.709", "2018-12-21 14:12:22", 273.444, 267
2018-12-21 14:16:50, "TrackPlay", "EmbeddedContainer", "OVERLAY:publislot1", " [1 Entries]", "Embedded Container", "Embedded Container", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "-1.000", "2018-12-21 14:16:50", 13.820, 13
2018-12-21 14:17:03, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\70\David Bowie - Rebel Rebel.mp3", "David Bowie", "Rebel Rebel", "Best of Bowie CD 1", "David Bowie", "1979", "Rock", "", "", "100", "", "David Bowie", "", "", "EMI Music Distribution", "", "", "", "126.605", "2018-12-21 14:17:03", 263.704, 263
2018-12-21 14:21:25, "TrackPlay", "Jingle", "C:\AUDIO 2019\Algemene jingles kompas\Radio Kompas - Classics Mix 15.mp3", "Radio Kompas", "Classics Mix 15", "", "", "2018", "Blues", "", "", "0", "", "", "", "", "", "", "", "", "121.705", "2018-12-21 14:21:25", 29.250, 29
2018-12-21 14:21:54, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\Caroline Loeb - C'est La Ouate.mp3", "Caroline Loeb", "C'est La Ouate", "", "", "", "Pop", "80s", "", "100", "", "", "", "", "", "", "", "", "97.224", "2018-12-21 14:21:54", 235.948, 235
2018-12-21 14:25:49, "TrackPlay", "EmbeddedContainer", "OVERLAY:OVL20", " [5 Entries]", "Reklameblok 1", "Embedded Container", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "-1.000", "2018-12-21 14:25:49", 107.053, 105
2018-12-21 14:27:34, "TrackPlay", "Jingle", "C:\AUDIO 2019\Algemene jingles kompas\2019 is het jaar van de classics, Radio Kompas Classics.mp3", "Radio Kompas", "2019 is het jaar van de classics, Radio Kompas Classics", "", "", "2018", "Blues", "", "", "0", "", "", "", "", "", "", "", "", "162.455", "2018-12-21 14:27:34", 8.824, 7
2018-12-21 14:27:42, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\Alison Moyet - Weak In The Presence Of Beauty.mp3", "Alison Moyet", "Weak In The Presence Of Beauty", "", "", "1986", "", "", "", "100", "", "", "", "", "", "", "", "", "107.024", "2018-12-21 14:27:41", 219.190, 217
2018-12-21 14:31:19, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\70\John Travolta & Olivia Newton-John - You're The One That I Want.mp3", "John Travolta & Olivia Newton-John", "You're The One That I Want", "", "John Travolta & Olivia Newton", "1970", "Disco", "", "", "60", "", "", "", "", "", "", "", "", "106.818", "2018-12-21 14:31:19", 161.017, 159
2018-12-21 14:33:58, "TrackPlay", "Jingle", "C:\AUDIO 2019\Algemene jingles kompas\Jingle Bells, 100% Kerst ,100% Nieuwjaar ,Een Fijne Kerst En Een Gelukkig Nieuwjaar (Swingend Muziekje).mp3", "Radio Kompas Xmas Liner", "Jingle Bells, 100% Kerst ,100% Nieuwjaar ,Een Fijne Kerst En Een Gelukkig Nieuwjaar (Swingend Muziekje)", "", "", "2014", "Liner", "XMAS", "XMAS", "100", "", "", "", "", "", "", "", "", "131.042", "2018-12-21 14:33:58", 23.299, 20
2018-12-21 14:34:19, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\70\The Real Thing - You To Me Are Everything.mp3", "The Real Thing", "You To Me Are Everything", "", "", "", "", "", "", "100", "", "", "", "", "", "", "producer", "", "102.719", "2018-12-21 14:34:19", 194.260, 192
2018-12-21 14:37:31, "TrackPlay", "EmbeddedContainer", "ITEM uittip", " [2 Entries]", "UITTIP", "Embedded Container", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "-1.000", "2018-12-21 14:37:31", 19.351, 5
2018-12-21 14:37:36, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\Level 42 - Running In The Family.mp3", "Level 42", "Running In The Family", "Hits of ..... 87+88", "", "1992", "Pop", "80s", "", "100", "", "", "", "", "", "", "", "", "124.995", "2018-12-21 14:37:35", 230.164, 228
2018-12-21 14:41:24, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\The Smiths - Panic.mp3", "The Smiths", "Panic", "Mastermix Classic Cuts 14 - Alternative", "", "1986", "Club", "", "", "100", "", "", "", "", "", "", "", "", "130.643", "2018-12-21 14:41:24", 132.375, 131
2018-12-21 14:43:34, "TrackPlay", "EmbeddedContainer", "OVERLAY:OVL40", " [6 Entries]", "Reklameblok 2", "Embedded Container", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "-1.000", "2018-12-21 14:43:34", 116.313, 114
2018-12-21 14:45:29, "TrackPlay", "Jingle", "C:\AUDIO 2019\Algemene jingles kompas\Merry Christmas (Kids) Hohoho ,Radio Kompas (FX).mp3", "Radio Kompas Xmas Liner", "Merry Christmas (Kids) Hohoho ,Radio Kompas (FX)", "", "", "2014", "Liner", "XMAS", "XMAS", "100", "", "", "", "", "", "", "", "", "147.882", "2018-12-21 14:45:29", 8.584, 6
2018-12-21 14:45:35, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\Cock Robin - When Your Heart Is Weak.mp3", "Cock Robin", "When Your Heart Is Weak", "", "Cock Robin", "1985", "Pop", "80s", "", "100", "", "", "", "", "", "", "", "", "105.662", "2018-12-21 14:45:35", 276.515, 271
2018-12-21 14:50:06, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\The Stranglers - Golden Brown.mp3", "", "The Stranglers - Golden Brown", "", "", "", "Unknown", "", "", "0", "", "", "", "", "", "", "", "", "62.078", "2018-12-21 14:50:06", 201.747, 202
2018-12-21 14:53:28, "TrackPlay", "EmbeddedContainer", "OVERLAY:publislot1", " [1 Entries]", "Embedded Container", "Embedded Container", "", "", "", "", "", "", "", "", "", "", "", "", "", "", "-1.000", "2018-12-21 14:53:28", 27.627, 26
2018-12-21 14:53:54, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\80\Diana Ross - Upside Down.mp3", "Diana Ross", "Upside Down", "", "", "1980", "Disco", "80s", "", "100", "", "", "", "", "", "", "", "", "107.986", "2018-12-21 14:53:54", 219.705, 218
2018-12-21 14:57:32, "TrackPlay", "Jingle", "C:\AUDIO 2019\Algemene jingles kompas\It's Christmas ,Radio Kompas (Slow).mp3", "Radio Kompas Xmas Liner", "It's Christmas ,Radio Kompas (Slow)", "", "", "2014", "Liner", "XMAS", "XMAS", "100", "", "", "", "", "", "", "", "", "105.691", "2018-12-21 14:57:32", 8.748, 4
2018-12-21 14:57:36, "TrackPlay", "Music", "C:\Audio\RK AUDIO 2014\70\Stevie Wonder - Superstition.mp3", "Stevie Wonder", "Superstition", "", "", "1972", "", "", "", "100", "", "", "", "", "", "", "producer", "", "99.888", "2018-12-21 14:57:36", 263.193, 261
2018-12-21 15:00:04, 26
Can you please indicate, which script-line is skipped, as in the provided LOG I can see, that all script-lines are executed and do return a track?!
You also say, that only 2 out of 3 script-lines are executed. To which script are you referring this? As in your example given, the script contains over 31 script-lines (probably 34)? So you might mean something different?!
Can you explain this in a bit more details, what exactly is skipped?
mdegroot
Post by mdegroot »
It's what I explained before. I have a script called "uittip". In that script, I have 3 script lines. A start jingle, a spoken item and a end jingle. The 2 jingles are fixed, the spoken item is randomly chozen. The "uittip" script is loaded into the main script in a container.
Problem is that sometimes only the start and end jingle from the "item" script are played, the spoken item is skipped.
When I test the "item script", The 3 script lines are working, none is skipped. When I open a new playlist from script template, also the 3 Scripts lines are working. BUT : when I go to any currently running script or playlist, and I add the "uittip script" in a container, again only 2 Script lines are picked instead of 3. That's what you can see in the "played log". 2 items, instead of 3. I don't know why the middle script line is skipped.
Grts,
Okay, so we are talking about the script-line 18?!
This script-line will result into a dynamic embedded script container; meaning the script will be executed when loaded into the DJ Player.
That’s why it isn’t listed in the script test log.
However, if sometimes the script can not resolve the random track between the 2 jingles, this means that probably a global rule is probably violated.
Or that the related media lib is unavailable at that time.
I guess it is a rule being violated.
The only way to detect this is actually to activate the Debug-Logging and see the log when the error is happening.
Or to run the individual script test on the uittip more often, to see, if it can be reproduced.
mdegroot
Post by mdegroot »
Update : I couldn't find any reason why the line was being skipped. The files were available, I couldn't find any rule that was involved with this script line. Only possibility was to change the names of the files, then they played again for about 2 days.
BUT : I found a solution for the issue, by enabling all the suppres options for that "uittip" script itself, instead of just enabling the suppress options on the script lines. Problem is solved, but I still have no idea why a file is added to the history, when suppress add history is checked? This media library containing the files is only used in 1 script. This script is then loaded into other scripts using a container.
Problem with the suppress add history option?
As said, the debug log would have helped to figure that out. But it the filename change also helped, it was probably one of the global restrictions, eg. a do not repeat within x hours or any other restriction or rule set.
