Optimiazation Our Playlists After ABCDE .
Ahmed Saied
Post by Ahmed Saied »
Hi Brend ,
I hope to be well , and i want to help me to optmaize our playlists after A B C D E AR/ EN like :
H :House Playlist , G :Country Playlist , N:MidTempo Pop , Q:Slow Pop , finally O:MidTempo Slow Arabic Songs.
I want to compile all these in one thing but I want to organize the years ,genre,mood without using filtation in the script !
what should i do to implement these that headache to me to update all of these playlist every week or 2 weeks ?
Thanks for caring ,
Re: Optimiazation Our Playlists After ABCDE .
Hi Ahmed,
I am not sure, what you exactly what to achieve and why you explicitly exclude the filter option for script-lines.
As without using filters you are obviously limited to managing all your content in separate media libs - which in the end means, that you need to manage/update them accordingly. And this also seems something you want to avoid.
However, there is no other magic way of doing so.
Ie. I suggest you just try to use the filter option...
