v4.0.3.18-stable
v4.0.3.18-stable
Version 4.0.3.18 is out!
What's New?
  • Axia Livewire+ GPIO support added
  • New Playlist option 'Fill Tracks til scheduled EndTime' added
  • New Playlist option 'Resolve Overlays to Playlist' added
  • New Script-Line mode 'TimeUpdateSync' added
  • New Script-Line mode 'LineIn' added
  • New embedded Container 'LineIn Feed' added
  • Advert Billing-Report error handling optimized
  • Campaign Priority extended
  • New 'Resolve Overlay to Playlist' item added to Upcoming Overlays
  • VoiceTracking of current playing track allowed
  • Clear Statistics bug-fixes
  • Advert PFL bug-fixes
  • Instant Recording file selector added
  • GPIO UDP Server bug-fix
  • Other smaller bug-fixes
  • stable
The GPIO client has been enhances by a new Livewire+ tab including the ability to configure two Livewire+ devices and related mappings.
In addition new Livewire+ control-commands and macros have been added, e.g. EXEC_SEND_LIVEWIRE1/2_GET/SET/SEND or ${LIVEWIRE1/2:GPI port pin}.
See the appendix of the user manual for details about these commands/macros.
The Livewire+ mapping defines either a GPO or GPI type, a Port and a Pin and allows you to react on any pin state value change.
The Livewire+ GPIO interface allows full 2-way communication with any Livewire+ supported device, e.g. from Axia.
New Playlist option 'Fill Tracks til scheduled EndTime' and 'Resolve Overlays to Playlist' added
These two new playlist buttons (see the Add/Remove ribbon tab) allow you to dynamically extent a scheduled playlist until its scheduled end time and to resolve all current overlays as playlist items into it. This works like an ad-hoc playlist template and allows on-the-fly voice tracking of a live playlist.
New Script-Line modes added
Two new script-mine modes 'TimeUpdateSync' and 'LineIn' added.
The first (imeUpdateSync) allows script based scheduling of a TimeUpdateSync, e.g. to ensure, that the subsequent script-lines are played starting at a defined time.
The second (LineIn) allows you directly schedule a LineIn Feed from with a script-line. It take the mixer input channel to use and the duration as its parameters.
Accordingly to the above 'LineIn' script-line mode, a new embedded dynamic 'LineIn Feed' container has been added as well.
This also allows you to now specify the 'AsPlaylistInsert' option with a 'LineIn' Overlay Scheduler entry.
The advert campaign priority value range has been enhanced for values below 0 and values above 100.
A campaign priority can be used to define the order in which campaigns are played within an advert slot. Campaigns with a higher priority will be played first (e.g. 60, 50, 40, ...).
Note: When using campaign keys this priority might get shifted resulting in campaigns with a lower priority being played first, as the campaign key is evaluated regardless of the priority.
However, priorities above 100 are always played first and priorities below 0 are always played at the the end (regardless their key).
So far, the 'Upcomming Overlay' popup window only allows you to start an overlay 'now' (ad-hoc), even for future entries. The context menu is now enhanced with a new 'Resolve Overlay to Playlist' item, so that it is resolved to its effective start time into the playlist.
Plus a few more little enhancements ...
