Not able to add users
Bumperke
Post by Bumperke »
I'm not able to add users in PF.
I checked, more stuff, User Access control (pw is ProppFrexx). See pic.
Not able to active enable UAC. How can i fix that?
KR
Will
Bumperke
Re: Not able to add users
Post by Bumperke »
Ahh, not i'm sad and have to recover the layout and view settings every second day. I guesss i have to shoot the dj's :)
Note, that you also have the ability to save and restore a 'Workspace'.
I.e. in case your DJs messed your layout, you can restore yours with a single click...
See the 'View' ribbon tab and make a click on the 'Workspace' ribbon button.
Example:
1) Make sure the layout of all windows is okay
2) Click on 'Workspace -> Capture Workspace' and enter a name for it (e.g. 'Default') and click OK
3) now rearrange some windows - to emulate a 'bad' DJ
4) Click on 'Workspace' and you'll see a new menu itam called 'Default' at the end - click on it
5) all your changes are reverted and the original captured layout is restored
Bumperke
Post by Bumperke »
You are a Hero, saved the life of several dj's Haaha, Thxs Bernd
For your 2nd machine you have purchased a Professional Edition - which did not include UAC, see here:
http://www.proppfrexx.radio42.com/editions.html
