Upload button for voicetracking
Bumperke
Post by Bumperke »
It just doesn't work everytime. After waiting several days not able to load up the homemade voicetrack. Is it possible to put an upload button in it?
So it is simple to upload?
Will
Re: Upload button for voicetracking
Yes, I'll ltake a look....
Til then, you can simply resume a started VT session by clicking on the 'Remote Voice Tracking....' button again.
Any open sesion will be detected automatically and you can then directly close the playlist to upload it again...
A v4.0.2.17-beta is already available - so please "Check for Beta-Versions..."
This now also includes a new 'Upload RTV Session...' button.
Bumperke
Post by Bumperke »
radio42 wrote:A v4.0.2.17-beta is already available - so please "Check for Beta-Versions..."
I'm curious Bernd.
Bumperke
Post by Bumperke »
I'm curious Bernd.
I'm still curious Bernd. I updated the system but can't seems to find any button? Where did you 'hide' it? LOL
Will
In the same menu where you also start the RVT session. That's underneath the 'New' main ribbon button.
The new menu item is called 'Upload RVT session...' and is only visible, if you have a remote session open which is not uploaded yet.
Bumperke
Post by Bumperke »
radio42 wrote:In the same menu where you also start the RVT session. That's underneath the 'New' main ribbon button.
Brilliant :)
Bumperke
Post by Bumperke »
Bernd, finally was able to try. Button showed, I did everything it asked and the upload was fixed in less then 30 seconds. And that was surprising. Since the folder in the server didn't change I've been asking what it did. Sorry, wish I could bring some better experiences.
I changed several songs in the playlist, so PF should upload those files as well, that either didn't happen.
Than another experience. I had an older ft on my computer which I had to upload, I wasn't able to do that as well.
I hope this info is useful.
Will
I just tried it here and it was working as expected.
Here is what I did...
Test 1:
1) I started a new RVT session on my client
2) all files have been compressed and downloaded
3) I did some VoiceTracking and changed the order of a few playlist items
4) then I saved and closed the playlist
5) when I was asked, if I want to finish and upload my RVT session - I selected 'NO' !
At this point, in the 'New' menu now the 'Upload Last RVT session...' item becomes visible
6) I selected it and confirmed 'YES' ... and could now upload my RVT session
Now I moved to my server and opened the Program Scheduler, right-clicked on the related item and selected 'Open Template Playlist...'
7) the related playlist opened and showed exactly all my files and the correct playlist order.
Test 2:
1) I repeated all steps 1) to 5) from Test 1
2) from the 'New' menu I selected again 'Remote Voice Tracking...' and I was told, that I have an old session open
3) I confirmed to continue it
4) my current RVT playlist opened again
5) I did again some modification to the playlist
5) when I was asked, if I want to finish and upload my RVT session - I again selected 'NO' !
The 'New' menu is still showing the 'Upload Last RVT session...'
So such: All tests passed!
All looks okay here!
I am not sure, how you are testing things...?
Please describe in detail how you are testing things exactly?!
I'll double check this later on.
In the meantime simply use the normal way to resume and upload your playlist.
However, note that there can only be one open RVT session at a time. I am afraid you cannot upload even another older session.
