ProppFrexx ONAIR.medialibs
atlantic
Post by atlantic »
I have changed my audio library of my hd C to D, but now the links to the folders are no longer correct. How can you change it without heading up all over again.
I have everything adjusted ProppFrexx ONAIR.medialibs but this does not help.
i use versie 4.0.2.1
Kind regards,
Marc
Re: ProppFrexx ONAIR.medialibs
What media libs are you using - only folder based libs?
If yes, have you closed PF before you adjusted the file "ProppFrexx ONAIR.medialibs"?
Here is an example...
<add key="C:\Music\Folder1" value="0||False|False|False|-1|False|Music||1|Folder1" />
To:
<add key="D:\Music\Folder1" value="0||False|False|False|-1|False|Music||1|Folder1" />
atlantic
Post by atlantic »
OK, Thanks
