Check playback history
SiriusRadio
Post by SiriusRadio »
Hi Bernd.
What do i do to check playback history from more than one day. I presume the lists will be saved?
And if, can you tell me where?
Will :D
Re: Check playback history
Are you talking about the Global Song History or the Playback History?
Note, that nothing is effectively checked against the playback history, but only the global song history.
However, you can adjust the size of both in the general settings, section 'Logging/History'.
Also note, that you can add additional checks/rules via the global 'Rule Sets', 'Restrictions' (both can also be found in the general settings, section 'Logging/History') or via the track related 'Restrictions' (see the TAG Editor's 'Other' tab, e.g. the 'Don't Repeat in' x days option).
SiriusRadio
Thxs 4 the tip. It is the playback History check.
Will
SiriusRadio
radio42 wrote:Also note, that you can add additional checks/rules via the global 'Rule Sets', 'Restrictions' (both can also be found in the general settings, section 'Logging/History') or via the track related 'Restrictions' (see the TAG Editor's 'Other' tab, e.g. the 'Don't Repeat in' x days option).
Is that in the 4 version? Can't find it in the 3.0.15.21 version
Will
Yes, all I write here is related to the latest v4 - Rules and Restrictions have been added in v4 ;-)
