The "Start ProppFrexx ONAIR with Watcher" option ignores if ONAIR is already open
Bo98A
Post by Bo98A »
Right now if you start the watcher with this option enabled while ONAIR is already open, it results in an infinite loop of a message box warning about it being a second instance and the watcher restarting that instance when you don't choose to open it. Would it not make more sense to behave like if that option was disabled if an instance of ONAIR is already open?
Re: The "Start ProppFrexx ONAIR with Watcher" option ignores if ONAIR is already open
That's a chicken and egg issue - so just don't do it that way ;-)
And no, as some want to use the allow multiple instances option as well, so I can not really behave like you suggest.
