OnUserLogin event does not fire when same user logs in again
Havenstad FM
Post by Havenstad FM »
In our setup i have linked a script command on the login and logout events. Now it happens that if a user logs out and the same user logs in again the OnUserLogin is not fired.
IMHO this is a certified bug as in our station we play dj-shows every evening and unmanned computer generated shows at night. Therefore it is quite possible that the same dj that logs out at the end of the evening is the same one that logs in again the next day.
Please let me know your view on this.
With kind regards,
Jack Reitsema
ITC Havenstad FM
Re: OnUserLogin event does not fire when same user logs in again
Yes that would be bug. I m on the road the weekend and check on Monday.
Yes, the "OnUserLogin" so far only fires when a new user was logged in - but not if the same user logged in again.
I didn't really assume, that this is a 'certified bug', as that behavior was so far actually by design - as the user effectively did not really change ;-)
But I guess it is okay to change the current behavior in the next version and fire the OnUserLogin event even it is the same user logging in again...
In the new v4.0.1.25 update the OnUserLogin should now be triggered even if the same user logs back in again.
Havenstad FM
At this moment the v4.0.1.26 is playing and indeed the OnUserLogin is firing whoever is logging in now. Thanks for the update.
Regards,
Jack Reitsema
ITC Havenstad.FM
