Remove jingle from Segue Editor (Multi Track Editor)
andrerotgans
Post by andrerotgans »
Stupid question perhaps, but how does one delete a jingle dragged in from the Explorer window into the Segue Editor? I can move it around, change the envelopes and so on. But if I want to get rid of it, I don't seem to be able to.
Best regards,
André
andrerotgans
Re: Remove jingle from Segue Editor (Multi Track Editor)
Ah, that's the one I didn't try yet ;) Thanks!
Click on it (the Track-Insert) and then press the "SHIFT+Del" key combo.
