v4.0.0.16 - stable
v4.0.0.16 - stable
Version 4.0.0.16 is out!
What's New?
  • MusicMaster import bug-fix
  • UDP Client/Server communication added
  • Other smaller bug-fixes
  • stable
A new UDP Server (see the GPIO Client application!) was added.
Plus 2 new control-commands have been added (EXEC_SEND_UDP and EXEC_SEND_UDP).
The UDP server accepts (if enabled) by default any local connections on port 14242.
The interface is a text (UTF-8 string). Each UDP datagram can contain exactly one control-command.
The reply is then directly send back to the sender client.
E.g. simply send the string “SHOW_ALERT_WINDOW Test|UDP is working!” (without quots) to the UDP servers ip address and port…
As such it works almost exactly like the existing TCP/IP control-command interface, but uses UDP as the network layer.
Note, that UDP is not a secure transport layer.
Else...this is basically a maintenance release.
