Licence & Windows 10 upgrade
Jungledede
Post by Jungledede »
I've some questions with the licence.
Today I test the demo and I'm interest in the purchase of one licence.
I saw that i could use some different way to activate ProppFrexx.
I think to use the USB method.
But, if one day I change my computer, how I do? I've understand that the licence will be not valid. It's a bad thing...
And Microsoft will release Windows 10. Today the computer who will receive PF is on windows 8.1. How the licence react to the windows 10 upgrade?
If I choose another method the issue will be the same?
What do you recommend in my case?
Sorry for my bad English :mrgreen: , I'm a French user interesting in your software.
Re: Licence & Windows 10 upgrade
The license will still be valid if you change your PC resp. the OS! So you might have misunderstood something...
It is just, that you might need a new registration key - that's all ;-)
As such, if you switch your PC or install a new OS version, simple write me an eMail with your new Ident-Number and your old registration data; and I will issue your new registration keys - it is pretty easy and you are NOT loosing your license!
Jungledede
Thank you for the answer, i wanted to be sure i can reinstall windows as many times as i want or change the hardware in case of problem. By selecting the usb stick method, i just have to re-enter my registration code after installing ProppFrexx, right?
Thanks
Yes, but only with the same OS version and .Net version installed it is ensured that the same Ident Number is generated. So with a different OS version you might still need to get new keys.
