AutoDuck bug
ExIT_FM
AutoDuck bug
Post by ExIT_FM »
I've discovered a bug in the AutoDuck. If I try to change the delay (General settings -> Mixing/Fading -> AutoDuck Settings) in the input section (eg. from 1000ms to 500ms) and I press the OK, then I open the AutoDuck settings again, the delay goes back to 1000ms. This bug appears in the version 4.0 as well :(
Regards,
David
Re: AutoDuck bug
Its the Input Speed which is not saved correctly. Yes, that will be fixed in the next version!
Thanks for pointing me to this.
