Voice Track doesnt work?
henkelar
Post by henkelar »
Hi!
I cant make my voicetrack work? What do I have to do? I have test with short commando and manually click on the icon, but no respond...
Maybe a bug? More than me with the problem?
// Henrik L
Re: Voice Track doesnt work?
I don't think so, there are many users already using that feature!
Please describe your exact steps to reproduce your issue - how are you testing things?
Make sure:
- to have at least one Mixer Input Channel defined.
- to have at least 2 tracks added to your playlist and you have selected the first one
- you are using either the Demo version or at least the Professional Edition
E.g. VoiceTracking is NOT available in the Premium Edition. See here: http://www.proppfrexx.radio42.com/v3/editions.html
henkelar
Post by henkelar »
I can also be me thats the problem...
I have only one Input Channel, and thats the one goes out. I understand that I need another Input Channel for Voice Track? Right? Trying to find anything in the manual but nothing to find there :(
How do I it right?
I have two tracks in the playlist but still no working.
I have the professional edition.
Yes, exactly.
See the general settings, section 'Input/Output'.
Here you can define a Mixer Input Channel - just click the related 'Add' button and configure it accordingly, e.g. use your connected Microphone device.
It is a bit hard to say what exactly you need to configure, as I do not know your environment and setup, what soundcard your have, where and how you connected your Mic etc.
But I am pretty sure you can walk your way with the mixer input channel configuration...
(I just moved this topic to Q&A, as it is not a bug)
henkelar
Post by henkelar »
I have solved it, i think :) Very simple :)
I found this:
viewtopic.php?f=9&t=29&hilit=voicetrack#p81
Thanks!
Glad you fixed it :)
