Select Advert Slot with filter generating
We have 2 commercials overlays, 1 before and 1 after the news.
We want to generate a schedule for a commercial that only needs to play BEFORE the news.
I know that we can manually add it but if we generate a schedule with the filter options it plans the commercial also in the overlay AFTER the news.
Is it possible that you can select a slot in this filter so it will generate only for that slot?
Or am I doing something wrong here?
Greetz Jesper
Greetz Jesper
- Naamloos.jpg (13.3 KiB) Viewed 6309 times
Re: Select Advert Slot with filter generating
Yes, I guess the filter might be extended accordingly in the next version!
Ok! Thanks Bernd. Looking forward to it!
Greetz
Greetz
In v3.0.14.20 you can now specify the overlay name, slot or reference class as additional filter elements.
Thanks Bernd.
I will try it asap!
I will try it asap!
