Clicking on playlist updates playcount and last played
When loading tracks into playlist, I have set to show the play counter and date last played.
I don't know what initial values it shows but when I click on each track line it updates those values to the latest.
https://dl.dropboxusercontent.com/u/683 ... 281%29.mp4
Re: Clicking on playlist updates playcount and last played
Yes I am using v3.0.14.0.
Tracks are loaded by a script filter.
I did not add or remove any column. It was there since start.
Yes
Strange, I can absolutely not reproduce the issue.
radio42 wrote:Strange, I can absolutely not reproduce the issue.
It happens here :?
Are you sure you are using v3.0.14.0 - as with that version I can not reproduce the issue here.
Please provide some detailed steps to reproduce the issue.
How did you load tracks to the playlist, did you ad or remove the 'Play Counter' columns in between or have they been shown already before you loaded the tracks...
So during the scheduler is actively running? and the playlist has been created automatically by the scheduler?
I didn't change the main code, but it might be fixed as the entry stats are now moved to the MLS.
So please try the v3.0.14.01 and make sure to read the notes in the news/announcements.
From a first view seems that it resolved.
