v3.0.13.32 - stable
v3.0.13.32 - stable
Version 3.0.13.32 is out!
What's New?
  • New script modes LeastTimesPlayed and LeastRecentlyPlayed added
  • Cartwall Cart-Linking optimized
  • Other smaller bug-fixes
  • stable
Both script lines act on the entry statistic and are similar to the Random mode.
But the pick the least times played track (PlayCounter) resp. the least recently played track (Last Played Date).
This feature was already designed by the ‘Play 1:1’ button/feature, but had a little issue. So with this version it should work as expected.
a) Ensure, that also the ‘PlayMode One by One’ is enabled
b) Then select multiple carts one after the other (e.g. hold the CTRL key while clicking the cart number field)
c) Optionally make sure, that the last selected cart has the Loop-Mode enabled
d) Then press the ‘Play 1:1’ button in the toolbar
e) E.g. this plays all selected carts automatically (and as the last one is looped, it stays with that last cart)
f) Then click onto your final cart to end the looping…
