Exception on close
Exception on close
After updating pf, it started automatically. But MLS was not running because it needed to close for the update.
So I tried to close PF to run first MLS.
The following exception raised:
28/05/2014 21:05:50 [v3.0.13.25]:********** Error/Exception Information **********
Error Message: Cannot access a disposed object.
Object name: 'f7'.
Error Type: System.ObjectDisposedException
Error Source: System.Windows.Forms.System.Object MarshaledInvoke(System.Windows.Forms.Control, System.Delegate, System.Object[], Boolean)
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at System.Windows.Forms.Control.Invoke(Delegate method)
   at ProppFrexx.f7.c(Object A_0)
   at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
   at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
   at ProppFrexx.ab.a(Exception A_0, Boolean A_1)
   at ProppFrexx.da.a(Exception A_0)
   at ProppFrexx.da.b(Exception A_0)
   at ProppFrexx.da.a(Object A_0, UnhandledExceptionEventArgs A_1)
********** End **********
Re: Exception on close
Looks like you tried to stop PF while it was still starting.
Anyhow, it should not throw an exception. I'll fix that with the next version.
