Repeated artists
djanji
Repeated artists
Post by djanji »
I do not know why I repeated the same artists in the playlist.
Re: Repeated artists
You Script History Count (see the 'Max. History' field in your script library editor window) is set to 1!
As the 'Max. History' (Script History Count) defines the size of the song history per script library.
Your will only contain one single track to check the history ;-)
So you might want to increase that.
What is the setting for your global history?
