v3.0.13.12 - stable
v3.0.13.12 - stable
Version 3.0.13.12 is out!
It is highly recommended to update to this version due to a memory-leak being found!
(see below: TaskbarAssistant removed)
What's New?
  • TaskbarAssistant removed
  • Generic M3U Program Scheduler Import optimized
  • Reminders now also support an hourly recurrence
  • Overlay Scheduler recurrence bug-fix
  • Other smaller bug-fixes
  • stable
Unfortunately I discovered a memory-leak which is caused by the taskbar assistant feature (which was just recently added).
This memory leak seems to be present in the taskbar assistant itself and is therefore out of my control (as its a Windows OS feature).
Therefore I removed this feature again, until the memory-leak is fix by either Microsoft or until I am finding a decent workaround!
The Program Scheduler Import module for the 'Generic M3U' format now also considers the given base folders.
Regular Reminders (within the Program Scheduler) now also support hourly recurrences.
dokos
Re: v3.0.13.12 - stable
Post by dokos »
In this version of the PFL Players missing one button ... Save Meta Data File
What happened with him? Have there not?
Thank you for your response.
Marian
No, the button is now simply hidden if you have disabled the use of .pfmd files - as if that option is disabled they are anyhow not used ;-)
So check your general settings.
dokos
Post by dokos »
I want to ask? You can do a simple function that is in the commercials where the opener and closer and the sound track. I just want to add a short track soundtrack before or after. That every song could have intro and outro different sound. Particularly simple setting in PFL player. Thus, as in the event editor, there can not be inserted soundtrack song before but only in song.
In the Advert Manager you can already define a Campaign Opener and Closer Track - isn't that what you are looking for?
