v3.0.13.10 - stable
v3.0.13.10 - stable
Version 3.0.13.10 is out !
What's New?
  • Taskbar-Assistant added
  • Advert Manager, Overlay Scheduler: Test Overlay added
  • Advert Manager, Overlay Scheduler: Assign Campaigns added
  • Advert Manager: Dynamic Campaign Filenames added
  • Program doesn't automatically start bug-fix
  • Track-Insert-Transition bug-fix
  • Attenuation Settings configurable
  • Filter-Test dialog optimized
  • Restore ribbon bug-fix
  • Other smaller bug-fixes
  • stable
ProppFrexx now supports taskbar buttons in the taskbar preview window.
Actually the user definable ribbon Quick-Access-Toolbar buttons are mirrored to the taskbar and as such you can define the buttons yourself.
Up to 7 taskbar buttons are available (that's a windows limit).
In the Advertising and News Manager you can now from within the Overlay Scheduler make a right-click on a existing overlay entry and then select 'Test Advert Slot...' to quickly see what campaigns and tracks are currently scheduled.
In the Advertising and News Manager you can now from within the Overlay Scheduler make a right-click on a existing overlay entry and then select 'Assign Campaigns To Overlay...' to quickly add dynamic campaigns to that specific overlay occurrence.
Note, that this dialog will also show any campaigns, which are assigned regularly to the Advert-Slot in general. As such this dialog also serves as an overview plus allows quick individual assignments to be performed.
As explained in this post: viewtopic.php?f=9&t=1005&p=3876#p3876
Dynamic campaign filenames are now supported.
In a very special situation, where a regular scripting program was following a non-scripting LineIn-Feed program an when an Overlay started exactly in parallel with that new program it might have happened, that the new program was not automatically started. This is now fixed.
The track insert attenuation settings (fading times at the beginning and end) are now configurable within the general settings, see section 'Mixing/Fading'.
Note, that these settings are also the default values for manual attenuations, e.g. with the Voice-Tracking.
The dialog to test a file expression (e.g. when invoked from within a script to test the filter condition for a certain media library) was enhanced to now also display possible history conflicts. 3 icons are available:
OK = entry is accessible and does not violate any history (script or global)
Warning = entry is accessible but it does violate a history (either script or global)
Error = entry is not accessible (file not found)
dokos
Re: v3.0.13.7 - stable
Post by dokos »
Advert Manager, Overlay Scheduler: Test Overlay added:
you can do it in the advertising managers so I can manually move the test advertising messages in the slot in the first position or the third insofar as I have more advertising messages.
Marian
I am not sure I understand you correctly?
Can you try to explain again what are you trying to do or achieve?
dokos
Post by dokos »
I want to ask whether it is possible to change the campaign each other in Test Overlay.
Sometimes I would like to manually change the order of campaigns.
No, that is not possible within the 'Test Campaign' option!
Note, that the campaign order is determined by the campaigns 'Prioriry' and 'Key' properties (click on the '?' icon at the top-right of the campaign edit dialog to learn more).
However, if you assign at least the following options to the related Overlay:
- AllowEditing
- AllowModeratorChanges
and define the show in advance time large enough, you can rearrange the advert campaign tracks yourself directly within the overlay player.
Doing that beforehand is not possible.
