ProppFrexx has stopped opening.
Re: ProppFrexx has stopped opening.
Please find attached an BASSENC lib update!
Unzip that file and copy the x64/bassenc.dll from the x64 subfolder to your ProppFrexx ONAIR install directory and overwrite the existing bassenc.dll file!
Please close ProppFrexx before doing so.
It looks like the Shoutcast2 server may have sent an oversized cipher key (the spec says 16 bytes max), and that overwrote some things because BASS_Encode_CastInit didn't enforce the limit. Here's an update that does limit it!
If it still won't work, this would mean, that the SHOUTcast2 server sends an invalid cipher key and thus any connection would be refused.
- bassenc.zip
- (46.22 KiB) Downloaded 372 times
WickedSpins23
Yes, that appears to have fixed the problem. I'm connected/
the cipher key from Shoutcast is that to do with the AuthHash?
Yes. Glad it is solved!
WickedSpins23
I will be giving it a good test run the next couple of days then on payday Friday I will be registering for the full version. Thank you for the support and patience
