Setup Cartwall Lights on Control Module of D&R Airence MK2
Re: Setup Cartwall Lights on Control Module of D&R Airence MK2
But that means, hat only the ${cwYcartXtrackname} macros might deliver different values!
Can you please send me your cartwall files/folders (plus the .pfp file, if it is a playlist based cartwall) - so that I can test with your cartwalls - as mine are also working - i.e. it doesn't look like a simulator vs. physical mixer issue anymore...
Knarrenheinz
Post by Knarrenheinz »
Yes, no problem Bernd!
To avoid any misunderstanding.
With cartwall files you mean the .wav audio jingles that I want to in the carts?
And the other files are the _synced_.pfp file that is inside the folders containing the jingles?
Can I send them via WeTransfer to: bn at radio42 dot com?
Correct. You can send the entire folders incl. all the files.
Thx
Knarrenheinz
I have just been sending them to you via WeTransfer on the e-mail adress I mentioned in my previous post.
Thank you very much!
I assume our journey continues... as to doesn't seem to be a simulator vs. physical mixer issue.
I tested your cartwalls locally and they work as expected - the LEDs change as desired and don't stay on all the time. This means, I still can not reproduce your issue. So there must be another difference.
Let us therefor try another option. Please use again the user command panel and a 3rd button. Please add the following commands to such button:
ASYNC
SLEEP 300
EXEC_SEND_DRAIRENCE_SETLED 255|0
EXEC_COMMAND2 ${cw1cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 1|2
EXEC_COMMAND2 ${cw1cart2trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 3|2
EXEC_COMMAND2 ${cw1cart3trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 5|2
EXEC_COMMAND2 ${cw1cart4trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 7|2
EXEC_COMMAND2 ${cw1cart5trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 9|2
EXEC_COMMAND2 ${cw1cart6trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 11|2
EXEC_COMMAND2 ${cw1cart7trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 13|2
EXEC_COMMAND2 ${cw2cart1trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 2|2
EXEC_COMMAND2 ${cw2cart2trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 4|2
EXEC_COMMAND2 ${cw2cart3trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 6|2
EXEC_COMMAND2 ${cw2cart4trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 8|2
EXEC_COMMAND2 ${cw2cart5trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 10|2
EXEC_COMMAND2 ${cw2cart6trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 12|2
EXEC_COMMAND2 ${cw2cart7trackname}|NOT(Equals())|EXEC_SEND_DRAIRENCE_SETLED 14|2
Now, change a cartwall until you experiance the issue and once you experience it, click on that new user command button.
Does the LEDs are now, after you clicked the button and the above sequence is executed, show the correct state?
If yes, we can continue and you can use the above sequence and replace the I:OnCartwallChanged and II:OnCartwallChanged events with the above code...
If no, please create a 4th button with the following command and send be the output:
EXEC_WRITE_FILE C:\cartwall_state.txt|au|${cw1cart1trackname}@${cw1cart2trackname}@${cw1cart3trackname}@${cw1cart4trackname}@${cw1cart5trackname}@${cw1cart6trackname}@${cw1cart7trackname}@${cw2cart1trackname}@${cw2cart2trackname}@${cw2cart3trackname}@${cw2cart4trackname}@${cw2cart5trackname}@${cw2cart6trackname}@${cw2cart7trackname}
This file will add a line to a file "cartwall_state.txt" each time you press the button. It will contain the name of your cartwall entries.
So change a cartwall and then press the button...
Knarrenheinz
I loaded a cartwall with 4 jingles and 7 buttons light up. When I then press the 3e User Command button only the 4 correct buttons light up! :)
After changing the I: OnCartwallChanged and II: OnCartwallChanged with this new code; it works!!! :D
I can now change from 4 to 7, 7 to none, 7 to 4 and so on..., in both cartwalls with all buttons lighting up correctly on the Airence! How cool is that! :lol:
Do you have any idea what caused this difference between the simulator and the physical mixer?
Now this is what I call real support! Without your help I probably wouldn't brought this to a good end. I actually don't know how to thank you! :oops:
I cannot say this enough, but thank you so much again for putting so much of your valuable time into this!
ProppFrexx ONAIR: The best Radio Automation software and Support!
Very friendly and thankful greetings,
Ivan
Glad it is working!!!
I guess there is no difference - in essence it was the same commands as before.
