Open Sound Control (OSC) with your iPhone/iPad
Bumperke
Re: Open Sound Control (OSC) with your iPhone/iPad
Post by Bumperke »
Less that 4 years later you should think things change or get more simple, unfortunatly! It isn't. Same network issues and changed procedures. Phff.
EDIT: I'm definitly sure that i'm connected with the same network. The PF machine in connected over LAN. Maybe you know?
Bumperke
Post by Bumperke »
radio42 wrote: 17 Aug 2018 11:44 Maybe I know what? Not sure what exact network issues you have and I am afraid, that I cannot really solve them, as from a ProppFrexx perspective there is not much involved.
The most problems (in the past) have been by 'connecting' the TouchOSC component to the network. Maybe this is also the case in your situation?
Petty sure it is, last quote wasn't yours to get. i just wanted you to know that these same issues are still actual.
Well, I personally never had this kind of network issues - but I know, that some TouchOSC customers had this in general (some of their issue where even related to Windows, Firewall or AntiVirus dependencies) - so I cannot really comment on this, as this is out of the ProppFrexx scope.
Bumperke
Post by Bumperke »
i'm not able to connect the TouchOSC. Tryed everything. The editor does not connect to my ipad. All my settings looks oké. The software will not sync. Makes me feel like a loser.
Have you tried to contact TouchOSC?
Bumperke
Post by Bumperke »
radio42 wrote: 17 Aug 2018 15:15 Have you tried to contact TouchOSC?
The reaction was predictable. Look at our FAQ, still not working -)
Will
I am afraid I am also not really able to help.
The FAQ of TouchOSC mention, that some times some Apple services are not installed properly and that this might often cause network connection issues.
Unfortunately I cannot deal with this kind of Apple/TouchOSC issues here - even if I wanted. I am really sorry.
RADIORFMNL
Post by RADIORFMNL »
Have anyone the new files?
with cartwall in place of cardwall?
I guess there was never a correction done with the typo adjusted.
However, you can simply do this yourself using the TouchOSC Editor - as that is just the static text to be corrected isn’t it.
