GUID... Bug?
djbony
Re: GUID... Bug?
Post by djbony »
To temp folder I recorded a song. I set him a mixing points and put a album picture. Then I moved it to Trackboard and exported to Powergold format. Then I marked track moved to the target directory - with Tagger. ProppFrexx was launched and aired. I looked up the song in Propp and the new song had a different GUID. I ordered changes...
Re: GUID... Bug?
So you never clicked on any 'Save...' button anywhere in the Tagger? That might explain it...
djbony
Re: GUID... Bug?
Post by djbony »
In Tagger I clicked to "Save" several
djbony
Re: GUID... Bug?
Post by djbony »
Propp simply assign a new GUID to the new song.
Re: GUID... Bug?
No, but what should I say...
I tried to explain it a lot, I asked you to provide the exact detailed steps several times, but you did not...
So by just repeating you have a new GUID, I am sorry, but I can not help on that level.
Either you tell me your every exact steps (very details, tell me exactly what you are doing, which menu item you choose, what button you press, in what exact sequential order etc. etc.) so I can try to reproduce your issue ... or I can not help much ...
Re: GUID... Bug?
No steps? So I assume you can not reproduce the issue yourself and I can consider this topic closed?!
djbony
Re: GUID... Bug?
Post by djbony »
Please wait. We are moving into a new house. I worked on a few
djbony
Re: GUID... Bug?
Post by djbony »
Hi Bern,
here is my steps:
1. Put new songs to the temp foldier
2. Set mixing points in Tagger
3. Copy new track to Trackboard and export it to .csv file for Powergold
4. Move song to the destination foldier via Tagger
And than:
When PFOA is not running and turn it on after transfer the new songs, the GUID is not changed. When PFOA runs and plays, sometimes a change occurs GUID - randomly. Btw. In MP3 TAG is GUID still original from Tagger. PFOA shows and used another - maybe bug in auto-scan TAGs form new files and update _synced_.pfp. I Don't know.
djbony
Re: GUID... Bug?
Post by djbony »
Yes, changes I saved. Than I closed Tagger, open it again, refresh foldier and check GUID with Alt+2. All OK..
djbony
Re: GUID... Bug?
Post by djbony »
I send It to you via email
