Ok, so am I stupid?
Re: Ok, so am I stupid?
When you stream from within ProppFrexx to the Rocket server, you do not need to capture anything, but ProppFrexx directly sends and updates the metadata. All is configured in the Streaming Server configuration.
Ie. you setup a new streaming server entry in ProppFrexx.
Even when you don’t stream from within ProppFrexx but use an external application, you can still use such Streaming Server config entry to perform the meta data (song title) updates (just don’t start the server but set the option to force the title update).
I hope, that this issue (update meta data to rocket server) is also solved?
