Automatic generate playlists in one go.
gerritk
Re: Automatic generate playlists in one go.
Post by gerritk »
Also on a clean laptop with demo version it doesn’t work. Thx once more
kruse
Post by kruse »
I cannot seem to get the automatic generating of playlists to work, as I don't find the playlists. Where do I go wrong?
What Edition are you using?
And have you taken a look at the ProppFrexx AppDataUser folder.
You can also manually pre-generate a playlist out of the Program Scheduler. Just make a right-click on an existing entry and select the related entry from the context menu.
If no Generate Playlist Template context menu item is present, your Edition might not be sufficient.
kruse
Post by kruse »
I got Enterprise.
When creating a template from the Scheduler, I get this message, but there is no folder with that name nor any files in it.
And then I try to open the playlist from the scheduler in order to edit it, I get this answer:
2 Open playlist template.PNG (4.77 KiB) Viewed 46715 times
Sorry, but I am a little lost here.
Did you select ‚Next‘ and finally yes above in the first screen?
If yes, the above mentioned ‚Effective‘ folder should be created automatically.
That is indeed odd, if nothing is created.
Can you post the program entry and the related script you used in the program.
Any News on this one?
kruse
Post by kruse »
Ahh, I got it to work from the scheduler by following your instructions.
I'll skip generating playlists five days ahead, because by manually creating them, I can see in the scheduler that they were edited :)
Thank you again for a great software!
gerritk
Post by gerritk »
Is Generate Playlist for Selected only for enterprise version? It still doesn't work with my professional version
Yes, as posted in the other thread, the automatic playlist (pre)generation is and was only working in the Enterprise Edition.
Why do you write ‚it still doen‘t work‘?
The feature was added in 2017 and you own a license since 2019 and it was always only working in the Enterprise Edition.
Ie. manual playlist template generation also works in the Professional Edition, but the automatic feature needs the Enterprise Edition.
gerritk
Post by gerritk »
See my post before this one. I told you in the past I used the Professional licence. Sent you a short video. Reaction was you didn't know why it would not work on my machine.
Know I understand why.
