news ftp download time problem
moogwill
Re: news ftp download time problem
Post by moogwill »
Ok... then how can I be sure that the news is loaded in the Third next?
It should be when you load it 8 Minutes before, shouldn’t it be? as it is either loaded into the 3rd player or not loaded at all yet.
Else please explain where else it could be placed?
moogwill
Post by moogwill »
sorry in this particular studio I'm using 4 players... could it be a solution to reload all players except the one running?
When you are running 4 players than the 3rd and 4th next will be reloaded.
I still do not get to where your embedded script container is loaded to?
moogwill
Post by moogwill »
ok then it must be o then will re-check on mionday. maybe was my mistake the first time, yesterday all news was correctly played :-)
moogwill
Post by moogwill »
so after 3 days, I'm afraid it won't work.
I tried to move the download reminder.. but it doesn't change anything.
When too early there's no file to download.. then the file is saved as a 0k file, or when too late seems it can't save the file... even if it's not loaded in the player (only in the playlist)
moogwill
Post by moogwill »
note that when the container is loaded to the playlist theres only the opener and the closer.. then if not loaded to the player, I force the ftp download using the test fonction in the reminder edit. and then if I pfl the news then the right file is correctely inserted.....
That is strange, as I tested it successfully.
Are you the download does not work?! Ie. did you check the file once the reminder has been triggered?!
Maybe it is just the issue to also reset the 2nd next player?! (Eg. Player B; remember today only Player C or D would be reset, in case Player A is currently playing).
I would also not understand, why there should initially only be an Opener and Closer! As else there would be no News file! But if there is no News file, how could it be opened, so that a new download could overwrite it?
moogwill
Post by moogwill »
It's a complete nightmare so let me detail what exactely happened.
at 15:52 as it is supposed to be the reminder download and save the file... but.; I dont know why the same file is modified at 15:54 and the new file is 0.0K then trhe loaded file in the player was a container with only the opner and the closer...
moogwill
Post by moogwill »
some screen caps can't see the size on the cap sorry but it's 0k
message reminder.PNG (8.26 KiB) Viewed 11485 times
flash 0.PNG (4.09 KiB) Viewed 11485 times
