Metadata
Radiofreak
Re: Metadata
Post by Radiofreak »
At 17:00 hour the programme Eenmaster is playing but no meta data.
Re: Metadata
Where have you entered ‘nieuws’?
And are you for sure using the ${trackname} macro as the streaming update songtitle format?
Radiofreak
Re: Metadata
That's a overlay. At 17:02 starts the show.
Yes Trackname
Re: Metadata
What exact version are you using, as I just re-tested it here and can not reproduce your issue.
Please describe how you are testing this?!
Regarding your overlay: what have you selected for 'Title Updates' in your overlay entry settings?
Here I simply assume, that your have selected 'Use Track name', but your news audio track isn't properly tagged?
This however, wouldn't have anything to do with the script-line 'T' button option?!
Radiofreak
Re: Metadata
I use version V4.0.5.38 professional edition.
I test it by scheduling the program and see what the metadata says.
The overlay is not a problem at all that is working fine. As you can see on the screenshot, the news comes every hour by overlay and then the program starts. After the program starts what is a prerecorded program from a hour (mp3 file) ther is no metadata given. I mean the metadata what i must fill in by T.
In my opinion i do everthing what you tell me but it dosn’t work.
Re: Metadata
I guess I finally got your point!
A v4.0.5.39-Beta (so use "Check for Beta-Versions..." to update) is available, which should now hopefully fix it.
Radiofreak
Re: Metadata
Instaled the Beta version but stil no Metadata from “T” unfortunately.
Re: Metadata
Then you do something wrong somewhere.
I can only offer a paid TeamViewer session in this case.
Radiofreak
Re: Metadata
No thank you. I will let it go then. Thanks for your time.
Re: Metadata
I’ll send you a video later today which shows how I do and test it. Then you can compare.
