GUID... Bug?
Re: GUID... Bug?
Any news?
Could you reproduce the issue when using my steps?
Re: GUID... Bug?
Hi Bern, I do not get it. Suddenly, it works! I tried it with just one song. I try more of them at once.
Re: GUID... Bug?
Windows 10 and PFOA after the update to version 4.0.1.16 also
Re: GUID... Bug?
So we can consider this as solved?!
Re: GUID... Bug?
Again... Why? Any idea? After move file via Tagger...
- 1.png (163.27 KiB) Viewed 12976 times
- 2.png (297.54 KiB) Viewed 12976 times
Re: GUID... Bug?
From the screenshots I can not follow what you are doing!
Please describe the exact steps to reproduce the case - as I did above!
Maybe you reloaded/rescanned you libs when you (re)move you tracks and reloaded/rescanned them again after it was moved... and such the GUID got lost within the media lib (playlist file) and when the file was added back again it just got new GUID.
As said, I have no idea what you are doing by just looking at two screenshots
You even said in a post before: I is working fine ... so there must be some step(s) you performed where you actually loose the GUID.
Re: GUID... Bug?
I moved song with Tagger to destination folder. In PFOA I had to find that song, and he suddenly had a different GUID. Tagger but still reported the original... I don't understand...
Re: GUID... Bug?
Please describe the exact steps to reproduce!
E.g. what did you exactly do? How do you exactly move or copy the file, what menu item do you use, etc. etc.?
If just move a file to another folder, here the GUIDs do never change - as explained in my post above!
Maybe you did not saved your changed before you moved the files?
