Song title info in Proppfrexx ONAIR
Re: Song title info in Proppfrexx ONAIR
Again, this is a ProppFrexx support site and NOT a HTML support page!
If you need help, please consult a web-developer or try to google for your issue, e.g. like this:
http://www.htmlgoodies.com/tutorials/ge ... hp/3479551
janarz
Post by janarz »
Hey,
I have new problem..how i can be excluded ads with song title..
janarz
Post by janarz »
Media is not tagged.
We playng ads same way as the songs.
Yes i use licensed version of Proppfrexx.
janarz
Post by janarz »
My license is registered to [email protected]
How i can tagged my media ?
I known this program little..
If your media entries are tagged accordingly and you do use a dedicated media entry type (e.g. Advertising or Commercial) you can exclude those entry types from the automatic song title updates.
See the general settings, section 'Streaming' - 'Exclude from Title Update' option.
In addition, if you are using the overlay player to play your ads, note that you can also define directly within the overlay scheduler entry (see the 'Title Update' option), if and how you want to update the song title info.
It seems, that I can not find you as a registered user so far, so could you tell me what license you are currently using or if you are still evaluating the demo version?
Under which name have you licensed your version? Probably not under the email and name you are using here?
However, you then should/must tag your media entries accordingly.
Else, how should ProppFrexx differentiate and know, if you are playing a regular song (for which you want to perform a song title update) or if you are playing an advert (for which you want to suppress the song title update)?!
Open the TAG Editor (e.g. via ALT+3) or right-click in the playlist and select from the context menu 'TAG and Meta-Data' -> 'Edit TAGs...'
In the TAG Editor dialog you can set the 'Type' in the 'Track Data' tab.
Now click on the 'Save Meta Data TAG' button and finally on 'Save'.
You might also the stand alone ProppFrexx Tagger application (see your start menu) to tag your files.
Also see here:
viewtopic.php?f=5&t=1018
