Memory Leak
djanji
Re: Memory Leak
Post by djanji »
It looks like this every second a tone of entrys :(
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Bumerang - Najdi si drugega, Album=Slo 70s Rock I, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Martin Krpan - Se je cas, Album=Slo 80s Rock, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Res Nullius - Revolver ljubezni, Album=Slo Rock Legende 2, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Rdeči baron - Vodja, Album=Slo 80s Rock 3, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Artist' is strict contained in history (Entry=Oko - Sam sam, Artist=Oko, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Martin Krpan - Kar je staro, se novo zdi, Album=Slo 80s Rock, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Sokoli - Crna Luknja, Album=Slo 90s Rock 1, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Kameleoni - Sjaj izgubljene ljubavi, Album=Slo Rock Legende 2, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry directly contain in history (Entry=Requiem - Zvezdno nebo, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Tinkara Kovač - Nič je vse, Album=Slo 90s Rock 1, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Lacni Franz - Naj ti poljub narise ustnice, Album=Slo 80s Rock, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Requiem - Zdaj Je Cas, Album=Slo 90s Rock 3, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Avtomobili - Ljubezen ne stanuje tu, Album=Slo 90s Rock 1, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Buldožer - Helga (Live), Album=Slo 80s Rock 3, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry directly contain in history (Entry=Avtomobili - Enkrat v življenju, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Wellbott - Cebelica Maja, Album=Slo 90s Rock 3, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Lacni Franz - Ne mi dihat za ovratnik, Album=Slo 80s Rock, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Martin Krpan - Je v Siski se kaj odprtega?, Album=Slo 80s Rock, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry directly contain in history (Entry=The Drinkers - Žeja, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Pomaranca - Uniformiranci, Album=Slo 80s Rock, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Rdeči baron - Tvoje telo, Album=Slo 80s Rock 3, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry directly contain in history (Entry=Rdeči baron - Nikdar več nazaj, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Mladi levi - Sveti Štefan, Album=Slo Rock Legende 2, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Artist' is strict contained in history (Entry=Buldozer - Slovenija, Artist=Buldozer, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry 'Album' is strict contained in history (Entry=Boomerang - Okreni me, Album=Slo Rock Legende 2, MaxHistory=100)
13.7.2015 2:45:49: Global-History: entry directly contain in history (Entry=JERNEJ ZORJAN - NAJINE BARVE, MaxHistory=100)
Re: Memory Leak
That's what I said!
So you should check your Global-History settings resp. your Scripts resp. your Audio file TAGs!
I assume the entries are almost self-explaining.
So either an entry is directly contained in the history, or the 'Album' or 'Artist' violates the history check.
So probably your number of tracks (incl. the given 'Album' or 'Artist' diversity) are too low for your history settings?
djanji
Re: Memory Leak
Post by djanji »
Hope I done it right :)
Thank you
Bernd
Regards Jani
Re: Memory Leak
As I don't know your Global History settings, nor your Media Libs nor your Scripts - I also don't know.
Re: Memory Leak
Take a look to the file you try to open! It might be very very very large!
Probably it contains many many debuf log error messages, probably 'History Check' errors - which could also be the reason, why your playlist stopped playing, as there couldn't be any new tracks scheduled; as all your tracks are already contained in the history.
And thus the debug log file can not be opened, because you will get an out-of-memory exception. This can happen, if you do not have enough memory to open it OR the file is too big to be opened in an editor.
Again: An Out-of-Memory exception has nothing to do with a Memory-Leak!
Please check the file size and its content with the Windows Explorer!
Re: Memory Leak
A 1.6 GB large file can hardly be opened ;-) Thus the out-of-memory error.
I have already written it above...
I assume there are tons of History Check warnings inside the Debug log file!
Probably because almost all your tracks are already contained in a history and thus can not be scheduled.
But...
...you might take a look into that Debug log file yourself...
